cluster lighting
Old Dec 2, 2006 | 12:58 PM
RINO141's Avatar
RINO141
cluster lighting
HI guys need help everything was working fine turned the lights on and no inst lighting no radio lights or AC panel lights, I checked the fuses all good. By the way its a 99 F-250SD ext cab 6.8L
THANKS
Old Dec 2, 2006 | 09:03 PM
Franklin2's Avatar
Franklin2
Turn the headlight switch **** and see if they try to come on.
Old Dec 11, 2006 | 07:41 PM
RINO141's Avatar
RINO141
I operated the switch nothing,I checked the cluster lights all good.
Old Dec 11, 2006 | 09:27 PM
Franklin2's Avatar
Franklin2
Turn the headlights on, pull the fuse for the cluster lights, and see if you have power on one of the fuse terminals. If you do, then you are getting power from the headlight switch, and the problem must be downstream. If you are not getting power on either fuse terminal, there is something wrong with the headlight switch or the wiring to it.
