Sponsored by: Real Truck
4x4 not engaging
Old Dec 2, 2006 | 11:22 AM
kevinwebster1's Avatar
kevinwebster1
4x4 not engaging
when i switch it to 4x4 on the fly it sometimes doesnt engage. heres what is happining. i plow snow during the winter and last night we were out doin that and i bassically run up and down these lots in forward and reverse. so whe i get there i drop it all the way to first with it in 4wheel drive and push to the curb, then throw it in reverse and haul *** backward. and i pretty much leave the truck in 4 wheel for days when its bad out. but why would it sometimes not have the 4wheel engaged when im shifting from 1st to reverse all the time. oh and it will engage after a little bit sometimes. but not right away.
Old Dec 2, 2006 | 12:08 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Sounds like you have a vaccum leak in the system. Check all hoses for proper connection. Might have loosened one up.
Old Dec 2, 2006 | 12:26 PM
Maxium4x4's Avatar
Maxium4x4
Moved from the 6.0 section...
You will find a better answer here in the Super Duty section.
Old Dec 2, 2006 | 04:07 PM
jetskiman6969's Avatar
jetskiman6969
I'm not trying to hijack this thread, but I'm having a similar problem with my 99 superduty. For some reason, I'm NOT able to do a search on FTE.....WTF??Anyways, when I engage the FWD with the dash mounted switch, the transfer case engages, but not the hubs. After checking everything out, the solenoid switch that puts vacuum to the hubs does NOT get any power. I checked the manual for the right fuse, and there is power going through the fuse, but NO power at the wires going to the solenoid......ANY ideas??? Thanks in advance.
Old Dec 2, 2006 | 09:53 PM
DD1684's Avatar
DD1684
Vacuum seals are probably toast. That's what happened to mine when the 4x4 didn't engage.
Old Dec 3, 2006 | 07:42 AM
bigskymt's Avatar
bigskymt
I have a 99 and had the same problem. Took it to Ford and they had to replace something with the vacuum system, I forgot what but it cost $300.
Old Dec 3, 2006 | 09:59 AM
kevinwebster1
do you guys know of any threads in here that talk about where the vacuum system and solenoids and all that stuff is? i wish they would come out with a chilton manual for the new trucks, but nooooooo we have to take it to ford or figure it out ourselves.
Old Dec 3, 2006 | 01:16 PM
blackhat620's Avatar
blackhat620
kevinwebster1,
You can get factory manuals here
http://www.motorcraftservice.com/vdi...ageid=&gutsid=
Click on purchase subscription on lower left column. You can subscribe for 3-days ($9.95), 30-days ($16.95) or 12 months ($99.95) and download the manuals onto your computer.
Or if you want to buy factory paper manuals go here (FYI they can get spendy for the complete set)
http://www.helminc.com/helm/welcome_...KWVFR95921C082
Hope this helps
frafer1
Jan 14, 2009 11:13 AM
bentley
1997 - 2003 F150
Jan 10, 2009 05:01 AM
Insane Wheeler
Aug 27, 2008 06:11 AM
1975Ford
May 10, 2006 12:29 PM
