Sponsored by: Kumho
Steering Wheel Alignment HELP Please
Old Dec 1, 2006 | 02:50 PM
cndream1's Avatar
cndream1
1999 F250 Super Duty. Had it to the alignment shop three times and they still cant get the steering wheel to line up perfectly at the 12:00 position. Its been at 11:30, 1:30 and everywhere in between. I have verified that the caster, camber, and toe and all right in the middle of the spec range. So , can anyone tell how I can simply readjust the either one or both of the tie rod turnbuckles to move the steering wheel left or right and center up the wheel. I am tired of driving half across town and messing with the shop. I should be able to make a small adjustment to correct this mtself , ?no?
Thanks
Steve
Old Dec 1, 2006 | 03:52 PM
andym's Avatar
andym
Nope, that's why they have alignment shops. Speaking of which, you need a new one, because whoever's doing it now has no idea what they're doing.
Old Dec 1, 2006 | 05:34 PM
385seriesHemi's Avatar
385seriesHemi
When you get an alignment there is a steering wheel lock tool they should be using that presses against the drivers seat and holds the steering wheel. First you lock the steering wheel at 12 and then you adjust the caster/ camber/ toe. Like andym said, whoever is doing it isnt doing a very good job, comebacks are not what a shop wants also you dont want either because you are spending more time waiting for them to fix it. Find a new one.
Old Dec 4, 2006 | 05:48 PM
SRD4X4's Avatar
SRD4X4
Find another shop.If it's 4wd,there's an adjustment sleeve in the Drag-link used to set the wheel.
Old Dec 4, 2006 | 09:08 PM
dechiknhaulr's Avatar
dechiknhaulr
Grab your tie rods and rock them back and forth. Sometimes, the sleeves get tight and cause the tie rods to bind if the tech is not paying attention.
I never liked using steering wheel holders, but they do work if the alignment rack is in good shape. Too often, I see techs bring a car up on the rack without putting the pins in the turnplates. This destroys the plastic bearings inside the turnplate, and doesnt allow smooth movement of the front wheels when adjusting. Hence, a crooked steering wheel.
Firefighter 1406
Dec 28, 2016 08:34 AM
gmammakn
Sep 3, 2016 10:14 PM
bebyb
Feb 15, 2016 08:22 PM
Old Coyote
Aug 26, 2015 11:37 PM
bigalows
16
Jun 1, 2010 10:45 AM
