Recently started driving my 1999 F250 again and wanted to check all the fuses. Don't have the original manual and Chilton's does not have a schematic of either of the fuse boxes, and local Ford dealer was no help. I'd like to make sure all the fuses are of the proper size but need a schematic of both boxes. Any suggestions? Thank you.
Use the second link...but I added the first just in case the second does not work. At Motorcraft Technical Resources home...just click on the left side for the "Owner Guides" link.
You can now enter your SD info...and get the latest .pdf Owner's Manual.
