1978 - 1996 Big Bronco
Could only shift to 4x4 low range only....
Old Nov 30, 2006 | 04:30 PM
rkotila's Avatar
rkotila
Hey guys! The other days I left out in my Bronco. 351W; C-6 tranny. I got a few hundred yards from the house when the shifter fell into 4x4 HI. (I had moved it to 4 HI reaching around it to get something in the floor and then moved it back to 2 HI before I left). It seemed like I just put the tranny in neutral. I stopped and couldn't get it to move again. Nothing in 2HI or 4HI. I would only move in 4 LOW. I could hold the brake while in the HI range and see the drive shaft wiggle between drive and reverse but would not move. I tried all ranges, shifting w/ and w/o engine running. I finally drove back in 4 low and parked it. I started it up about 10 minutes later in 2 HI and worked again. I have been scared of messing with the 4x4 and getting stranded since. What's going on? Any ideas?
Old Dec 1, 2006 | 10:01 AM
Kemicalburns's Avatar
Kemicalburns
so you have a manual tcase or electric. when shifting between 2hi/4hi rolling wont hurt a bit. just dont engage 4wd on dry pavement it will cause issues.
Old Dec 1, 2006 | 10:10 AM
rkotila's Avatar
rkotila
86; Manual Transfer Case.
Old Dec 1, 2006 | 08:18 PM
Black Ford XLT's Avatar
Black Ford XLT
rktiola, curious to know were your hubs engaged for 4 wheel drive , u say u have man. shifter . i feel u may have knocked it into neutral with out your hubs being locked TR
Old Dec 1, 2006 | 10:55 PM
rkotila's Avatar
rkotila
Yes, My hubs were unlocked, but I don't know why that would make a difference trying to get the transfer case back into 2HI or 4HI to just to get the truck back into gear. I couldn't get the truck to move unless I put it in 4 LOW.
Old Dec 4, 2006 | 09:11 AM
Kemicalburns
is your transfer case full of fluid. will the shifter not move past neutral?
