tail gate cables
Old Nov 29, 2006 | 07:12 PM
TRX250R87's Avatar
TRX250R87
tail gate cables
Where is the best place to find a replacment tail gate cable for my '05? WHat other years are the same?
ERIC
Old Nov 29, 2006 | 09:18 PM
Bob Jusnes's Avatar
Bob Jusnes
Probably the dealer. Maybe a junkyard, but the dealers price may not be that bad. 04-07 will be the same.
Old Nov 29, 2006 | 10:40 PM
is300wrx's Avatar
is300wrx
may I ask why you are looking for replacement cables? I am curious because I want to know what made it go bad? How many miles do you have on it? I load my atv on my bed using ramps and I believe that wears the cables down...I may have to replace mine sooner than normal users
Old Nov 30, 2006 | 08:14 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
That popular auction site also has them available...new and used.
Old Nov 30, 2006 | 09:14 AM
TRX250R87's Avatar
TRX250R87
I had the cables break on my last truck while loading my ATV, damaged the tailgate pretty bad! My current truck is an 05, is pretty clean, and h as less than 25k miles on it, but the left cable has the bubber/plastic coating split. I don't want the cable to break so I figured a spare would be a good thing to have.
I think the reason for the worn cable is from the http://www.ezdown.com/ tailgate prop.
ERIC
Old Nov 30, 2006 | 04:26 PM
96f150's Avatar
96f150
That ezdown is pretty cool, but don't forget, that doesn't make the cables any stronger
Old Nov 30, 2006 | 05:26 PM
is300wrx's Avatar
is300wrx
so how long do you guys think these cables last before going bad? Whenever I load my atv onto my bed using my ramps, I alwasy secure the ramp to my hitch from kicking back....but that aint going to stop the tailgate from falling off
Old Nov 30, 2006 | 06:05 PM
KrAzYKARL's Avatar
KrAzYKARL
thats some heavy atv, must have been a loaded up utility 4x4 atv. i got a sport raptor and they weigh only 400 lbs im sure a loaded utility can weigh up to (maybe over) 800lbs.
Old Nov 30, 2006 | 06:13 PM
is300wrx's Avatar
is300wrx
my atv weights about 600lbs dry....so with me riding it up...yea its about 800lbs...
Old Dec 1, 2006 | 10:37 AM
TRX250R87's Avatar
TRX250R87
Mine was a 350lb Honda TRX250R that I have loaded 100's of times in my '99 Mazda B4000. The cables must have been rusting from the inside because there was no visable sign of any problems until the day the cables snapped.
ERIC
Old Dec 1, 2006 | 12:12 PM
whitecrystal1's Avatar
whitecrystal1
ERIC
<X style="MARGIN: 0px">I don't think there is any way possible the ezdown caused the tailgate strap to go bad. I have one on my truck. If anything, I'd say it would prolong the life of them because it's not allowing it to slam down. <XX><XXXX>I would guess it was a defect in the cable or an overload of weight on them.
Old Dec 1, 2006 | 01:01 PM
TRX250R87's Avatar
TRX250R87
It seems like the prop does not allow for enough room for the cable so it almost folds in half, causing the cable to get wedged. This seems to wear on the rubber coating on the cable?
ERIC
Old Dec 1, 2006 | 01:47 PM
whitecrystal1
ERIC
It's to early for me to tell but I'll keep an eye on it, Thanks
