electric fuel pump
Old Dec 1, 2006 | 12:15 AM
fellro86's Avatar
fellro86
My holley is also a 5-7, which is about what the mechanical runs. I don't know of anything on the selector valve that will hold up to the draw. At this time, I tapped into the fuel solenoid, but want to get it on a relay sometime. I want to put a cutoff on it as well, for when I need the key on, but not the pump. Also works as a theft deterrent...
Old Dec 2, 2006 | 09:50 AM
lartross's Avatar
lartross
I feel kinda' stupid...I had a poor ground. Went straight to the battery...wrapped a wire around the tightening bolt, in the middle...and it didn't get tight enough. put a washer inside the nut and wrapped the wire there...works like a champ!
Old Dec 2, 2006 | 09:54 AM
fellro86's Avatar
fellro86
I just grounded mine straight to the frame, less wire, and put dielectric grease on it to prevent rust making trouble...
Old Dec 2, 2006 | 09:59 AM
2jhanna's Avatar
2jhanna
i did the same as fellro86, just grounded to the frame under one of the mounting screws for the pump.
