Fixed itself?....I doubt it but will see how it preforms in the morning. Supposed to get down to 10 above tonite. To cut to the chase...made an appointment with the stealership yesterday to get the 03's EBPV system looked at this afternoon. Ok, last night, I pulled the SuperChip program out of it(still under warrenty) and it was 19 degrees here this morning. Expecting it to chugg along after start up for a few miles untill the EBPV unsticks itself and comes open on it's own or whenever it decides open up...in the first couple of minutes or 3 miles down the road. You just never know.....WELL, as my luck always goes, would you believe that it preformed like a champ! After 3 cold starts today...no problem. Went ahead and went to the dealer and they scaned for codes and say they could fine nothing and sent me home. I told them that if it acted up again and the opportunity came up under very cold conditions, I'd leave it overnight and they could see if it would act up for them the next morning. Do you suppose it somehow fixed itself or was it just a fluke? I'm leaving the program out of it for the time being. Removing the program shouldn't have an effect on the EBPV system, should it? Sorry for being soooooo long winded! Thanks
Maybe ? The "warm up" systems on these trucks combines 3 systems - Intake air heater, Exhaust Backpressure, and high idle. The PCM uses 4 main sensors to monitor these systems - Intake Air temp, Exhaust backpressure sensor, Engine Oil Temp, Brake pedal applied. So if the tune is playing with any of the numbers or just has a small fault it could cause issues.
I start/warmup my truck on the stock setting, then maybe some high idle before getting underway. Only when it is well in the normal range do I flip it to a giddyup setting. Just this evening I got in it after a short hunt and started/drove off in the 40 hp setting. It made an unhappy sound up there and I could hear the EBV trying to do something and then it quit.
It was in the 60s today but had sat for a few hours. Thought I was good. Anyway, doesn't seem to do it in the stock setting.
Well, just an update on my EBPV problem. It didn't get as cold here last night as the thought, but was at 19 above this morning at 3am when I went to work. The truck preformed fawlessly on 2 cold starts so far today...so maybe "miracals" do happen! Will put the program back in it in a few days and see if that has any effect on it. Thanks
One more update and this thread can die......got down to 8 above this morning going to work and everything ran fine again...just like it's supposed to. Have the need for speed (and power) so put the chip program back in a little while ago. Hope it performs ok with it.
Well, I see some you guys wanted a "report"......NO GOOD! Went to a college basketball game last night....I'm guessing it was about 20 above when we came out. I remote started it and by the time we got to it, the EBPV was closed. Got out on the street and pushed the "go pedal" down and it opened up and I thought, "it's fixed".....NOT.....went about 10 blocks to the highway and put my foot into it again and she failed to respone. Whats odd about this is I noticed the temp gauge had risen to almost normal so you would think that the "whatever brain" that moniters the engine functions would have said to it's self, "Up to normal, good to go" Guess I'm down to uplugging the EBPV or pull the program. Any more input you guys might have would be appreciated. I'm going to see if it threw a code so will repot back then. Thanks
That is the KAM (Keep Alive Memory) code for the PCM - You wil get it if your
1. Battery or PCM has been disconnected.
2. battery cables loose or poor connection.
3. battery discharged.
4. open in KAPWR circuit.
5. blown fuse.
6. PCM
7. Very common just from having a tuner or chip
When you remove the program clear the codes if you can and see if it will come back
I just got back from a trip to town and as I stated earlier, it did show this code. I cleared it before I went to town. Temps were probably in the mid to high 20's and the truck ran like a champ...no indication of EBPV problems. Checked for a code when I got back and it didn't show any. Heading out again late this afternoon for another ballgame. Will see how it acts tonite...Thanks for listening.
Same thing happened again last night...same code..same outside temp....just a different night. Will pull the program next and see if that makes a difference.
