fuel air metering problems
Old Nov 29, 2006 | 12:17 PM
frappis's Avatar
frappis
Hi there, I've got 2 codes commin' up p1151 & p0174.
the 1151 says "manufacturer control-fuel air metering" the 0174 says " system too lean (bank 2). The fuel filter is ok....so what the heck do I check next????
any info would help....thanx
Old Nov 29, 2006 | 02:00 PM
pawpaw's Avatar
pawpaw
Welcome to FTE frappis.
It would seem the computer thinks is unhappy with the air fuel mixture in bank 2 & this would suggest a number of possibilities, maybe something is wrong with a fuel injector, or maybe fuel pressure, or even an air leak thats affecting just bank 2, or perhaps the O2 sensor for that bank is acting out.
So a little more info might help in deciding which would be the next thing to look at.
Which engine do you have in your 98 Ranger & how many miles on it????
Do you have any driveability problems???
Do you hear any ping from a lean mixture????
Did this problem come about suddenly after some event????
Old Nov 29, 2006 | 07:18 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I'd be removing the mass air flow.. and cleaning it up real nice.. sometimes they get contaminated with dirt or debris.. or oil (if you use a K&N filter)
Good luck.
Old Nov 29, 2006 | 08:55 PM
frappis's Avatar
frappis
Sorry for lack of info...the truck is a 4.0 auto 4x4 with 125k & jet chip...I changed the o2 sensor(bank 1 &2) about 10k ago. also I just cleaned the filter on the cold air intake(the filter was pretty dirty) it does start to sputter while going down any sort of decline---once the road levels out she runs fine?? tom. I will try the MAF---thankx a bunch for the tips!!!!!!!
PorchFarms
1997 - 2003 F150
Nov 23, 2014 02:18 PM
DocTrevena
1997 - 2003 F150
Feb 12, 2012 04:20 PM
PanJH
Nov 21, 2011 11:36 PM
Mustang6t7
Jul 10, 2011 12:14 PM
