Busted Leaf Spring
Old Nov 29, 2006 | 07:40 AM
spartan117_mc's Avatar
spartan117_mc
Busted Leaf Spring
hey all, i got a little problem. i've known about this for a while, but one of my leaf packs in the rear (drivers side) is missing a 6-8 inch chunk of one leaf. the truck rides hard because it does need nnew shocks, but other then that the leaf isnt causing any problems. i would like to replace the leaf however, 200-300 bucks for ONE new 5 leaf pack on a 78 f100 custom is a little outragous. does anyone know any place i can get them cheaper or anything i can do to remedy this problem? thanks in advance.
by the way, my brakes arent leaking... the fluid is staying i in the MC. me and my dad think it must have self bled becuase we never bled it and now the brakes work even better
Old Nov 29, 2006 | 09:52 AM
MBBFord's Avatar
MBBFord
You can go to a junkyard and get a used set of F150 leafs. I got a set for my F100 from a 86 F150, and it lifted it alittle and increased my load rating also, oh I got them for $35 too. If you don't want them to lift the rear of your truck, then take a middle leaf out and you should be good to go.
Old Nov 29, 2006 | 11:44 AM
79_250RangerLariat's Avatar
79_250RangerLariat
Sounds steep for the price of springs, where are you located? It's been a few years since I had to buy new ones but I was thinking I only had $400 in the set, and they were beefed up a bit.
I belive... springs off a 78-96 150, 250, 350 are all 3" wide and the same length. So a junk yard search would be pretty easy, just be sure to check the leafs over well so you don't end up with another busted one.
Old Nov 29, 2006 | 11:49 AM
monsterbaby's Avatar
monsterbaby
last time I bought leaf springs a 9 leaf pack for my one ton dually cost me $85 each side and included new u bolts. so that price is pretty high.
Old Nov 29, 2006 | 01:09 PM
Mil1ion's Avatar
Mil1ion
Self-Bleed ?
Not in this lifetime
Old Nov 29, 2006 | 01:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can build almost any spring you want by getting another set from the scrapyard and mixing the two sets. Match them as close as you can. Never just replace ONE leaf spring pack.
Old Nov 29, 2006 | 08:24 PM
460's Avatar
460
I'm guessing you are talking about 4x4 springs only? I think the 2wd springs are narrower, and the springs on my F350 are only 2 1/4" wide.
Old Nov 29, 2006 | 08:40 PM
George Frasier's Avatar
George Frasier
Another option is going to a spring shop and get a replacement (leafs or set). They do springs for trailers, cars, trucks, etc. Prices are usually reasonable and NEW.
Old Nov 30, 2006 | 10:59 AM
79_250RangerLariat
What year is you 350? The highboy's (77 1/2 and earlier 250/350's) had 2 1/4" or 1/2" springs (don't remeber which without measuring).
Old Nov 30, 2006 | 01:54 PM
spartan117_mc
thanks guys, i think ill probably look into a junk yard or too up here. there was one with a 4x4 late 80s early 90s f150. maybe ill rip the springs off of it. think theylly work? mines only 2wd though
Old Nov 30, 2006 | 05:02 PM
samickguy15's Avatar
samickguy15
Check the National Parts Depot catalog for spring information. It tells width, length, number of leaves, etc.
Old Nov 30, 2006 | 09:28 PM
460's Avatar
460
Mine is a '76 2wd cab/chassis with dual wheels. The springs have 10 leafs plus another 4 in the "helper" pack for a total of 14 leafs, and are 2.25" wide.
Here's the beast... http://i64.photobucket.com/albums/h1...1-23-06003.jpg
Old Dec 1, 2006 | 03:35 AM
wayneasbell's Avatar
wayneasbell
J.C. Whitney has the best price. $90 to $110 per spring includes U bolts and bushings.
Old Dec 1, 2006 | 04:03 PM
79_250RangerLariat
Hehe, she's a beast! I could get into trouble with that. Looks like a 1 ton so that would explain the narrow springs.
