Hello, I,m in the process of buying an 03 F-150 supercrew and was wondering if you can install aftermarket electronics on the factory stereo, amp ,sub,etc... Thanks for any input Denis
You can do anything you can afford. Home built you should be in the $450 area for a nice box and decent subs and an ok amp. Add in a line level converter and a couple of hours of playing around and your set.
I added subs to my stock 6 disc. Around april, I will be doing the high and mids with an amp and two good sets of speakers. So yes, stock or not it can be done.
Hi, Im new here so sorry if this is not where I should be posting..My 97F-150 has an factory amp, can I pull speaker level inputs to RCA form it( I dont know where it is either, had the truck since new) I want to hook up an MTX amp, already done the speakers need advice
