Growling Ranger
Old Nov 28, 2006 | 07:35 PM
Jimmysnook's Avatar
Jimmysnook
Growling Ranger
Hi y'all!
First post.
I Just bought a 2004 Ranger XLT 2x4 5-Speed a month ago (last truck was an 87 Ranger XLT 4x4 auto).
It runs like a top and drives like a dream.
When accelerating hard from a stop though, it makes a brief, low, growling noise from the rear end that ends around 10-15 MPH. This doesn't occur under normal acceleration. It sounds cool and doesn't make any vibration, but should I have it checked? My old Ranger didn't do that but it was an automatic.
Any advice?
Thanks,
Jimmy.
Old Nov 29, 2006 | 08:13 AM
sfcwoodret's Avatar
sfcwoodret
What type of rear end gears do you have?
Old Nov 29, 2006 | 08:20 AM
fordboy_52's Avatar
fordboy_52
Welcome to FTE jimmysnook. Im glad you chose the best site on the net for Ford-Trucks! See you around the boards!!
Matt
Old Nov 29, 2006 | 08:32 AM
matt's2.9STX's Avatar
matt's2.9STX
Check the door sticker for sfcwoodret's suggestion. Rangers are good about listing that. As long as no one modded it.
Old Nov 29, 2006 | 08:41 AM
pawpaw's Avatar
pawpaw
If this puppy is still under warranty, why not have it put on the record as a problem, by having a Dealer check it out.
Kinda sounds like maybe a thrust bearing or thrust washer, problem, but I'll bet their drive line Tech would know right away.
Do you have a limited slip differential????
Let us know what's found.
Old Dec 5, 2006 | 01:21 AM
Jimmysnook's Avatar
Jimmysnook
Thanx to all for your rapid replies.
I looked at the door panel and saw stats for axel weights, wheel size etc...
not sure what I'm looking for to find gear ratios.
I work 65 hours a week and it's like -18 wind chill here now and I was looking in the dark, but didn't see anything that looked like a gear ratio on the door sticker.
Will look again soon when I get a day off and see daylight again.
once again,
Thanks y'all.
