Bronco II Ford Bronco II
starting problem
Old Nov 28, 2006 | 06:43 PM
yardape24333's Avatar
yardape24333
starting problem
have problem starting when warm weather even if it hasen't been started for a day or two. starts good when the weather is very cold acts like the choke is sticking but fuel injection doesn't have a choke. any suggestions. vehicle has 150,000 miles but still runs fine.
Old Nov 28, 2006 | 08:14 PM
Dealford's Avatar
Dealford
Welcome To FTE !!!!
Have you tried to pull codes yet? This sounds like the Air Charge Temp (IAT) is not working properly???? There are 3 or 4 codes which define the exact fault if this is the case.
AL.
