Leaf Spring Removal 1990 F150
Old Nov 27, 2006 | 08:55 PM
oldcoupe42's Avatar
oldcoupe42
I dove into this one and would like to back track. What is the "preferred" method of getting the eye boltd out the rubber bushing of the leaf spring? I have already mangled the rear shackle by trying to beat the bolt out with a hammer and part of me wants the group to chime in and say "fire up the torch and burn rubber", but the fuel line along the frame rail has me concerned.
Thanks, Chet
Old Nov 27, 2006 | 09:08 PM
cc335's Avatar
cc335
Just did this job 3 weeks ago. Pain in the a**. The best method would be to remove the hanger from the frame. Should be 5 or 6 bolts, and are much easier than the main bolts. Replace the whole assembly, much much much easier.
Old Nov 27, 2006 | 10:16 PM
quicklook2's Avatar
quicklook2
you need to grind the head off the bolt and than hammer the heck out of whats left.
it is a pain in the ***.
Old Nov 28, 2006 | 02:47 AM
eco's Avatar
eco
I did this on a 1988 e-150 and it was a cake walk....hour and a half job (a couple of breaks in there) with hand tools, a floor jack and jack stands.
Old Nov 28, 2006 | 06:41 AM
oldcoupe42's Avatar
oldcoupe42
Eco, are we talking about the same job here? (Leaf Springs) The bolts that hold the springs to the mounts that are on the frame. The bolts are stuck in a rubber bushings that are on both ends of the springs. How did you get them out so easily?
Chet
Old Nov 28, 2006 | 07:39 AM
Conanski's Avatar
Conanski
Cut the bolts off with a reciprocating saw(sawzall). I replaced a spring set on my truck 2 summers ago and one of the bolts just refused to play nice. The saw got the spring pack out from under the truck where you can get serious about swinging a hammer.
Old Nov 28, 2006 | 07:47 AM
velcro7279's Avatar
velcro7279
The easiest way I have found is with the flame ax. If you torch the heads off be careful not to damage the hangers or shackle. It is a royal pain. I am in Michigan, the heart of the rust belt I think. All of my trucks have need a torch to work on the suspension. You could try drilling the heads off of the bolts with a drill that is just larger than the bolt, not sure if there is enough clearance to the bedside. I have usually just used the torch very carefully. Once you get the spring out yo can burn the rubber and the sleeves out eith the torch. It is stinky and messy, but it is the easiest way. Then replace with poly bushings. They go in easy and hold up very well. Just make sure you grease them when you put them in to reduce any chance of squeeks. You should be able to work out some sort of heat shield between the heat and the fuel lines if you think it will be a problem. It can be difficult, but it can be done. Good luck.
Steve
Old Nov 28, 2006 | 09:58 AM
LeoJr's Avatar
LeoJr
I don't burn the rubber out. I heat the metal around it. You'll actually hear the rubber pop as it separates and melts, just before the smoke starts it will push right out. I suspect the same is true of getting the bolt out.
Old Nov 28, 2006 | 12:01 PM
quicklook2's Avatar
quicklook2
nope, it is the rust holding the bolt to the metal sleeve inside the bushing.
Old Nov 28, 2006 | 12:18 PM
eco's Avatar
eco
Chet
Yes, rear leaf springs. I held the bolt with a box end wrench and I used another box end wrench to turn the nut off of the end of the bolt. Then once the nut was off I pulled and spun the bolt out. I did this at each end of the leaf spring and again at the shackle. Aside from that there are the u-bolts. A 1/2 in drive ratchet did the job there. I also removed the shocks...made the job easier because the rear end will move a bit more + I wanted to replace them too.
Maybe the job is different for the e-series???
Old Nov 29, 2006 | 08:11 PM
cc335's Avatar
cc335
The rear bolt melts to the hard rubber inside the leaf spring. Only way to pound out is by heating spring until that rubber melts, then pund while hot. Still think it is way easier to spend the $50 and get new hangers. Replace the whole assembly. my .02 cents
Old Nov 30, 2006 | 06:22 AM
oldcoupe42's Avatar
oldcoupe42
Update, was tempted to try and melt the rubber leaf bushings tho get the front bolt out, but the spring mount that is riveted to the frame was badly rusted so I chiseld off the rivets and ordered new mounts.
Chet
Old Apr 20, 2007 | 04:43 PM
Van Zant's Avatar
Van Zant
i ordered the hardware kit from bronco graveyard for this job and they sent me 7/8" bolts that dont fit through the springs or the shackle. weird.
Old Apr 20, 2007 | 05:33 PM
quicklook2's Avatar
quicklook2
that is why i go to the ford parts department.
not the cheapest but i get the right parts.
Old Apr 20, 2007 | 07:53 PM
Van Zant's Avatar
Van Zant
i take back what i said about bronco graveyard. they sent me the right parts. i forgot the front bolt was larger than the rears. i was just a little frustrated after spending a day on that total pita job.
