1978 - 1996 Big Bronco
Alternator problem?
Old Nov 27, 2006 | 09:24 AM
colad's Avatar
colad
Alternator problem?
Hi all,
I just put a new battery in my 91 bronco (351). As soon as I did my voltage gauge now reads just below the N in normal in the truck, my red battery light is on in the dash and the gauge doesn't move when I fev the engine but it does drop when I turn on the heater blower.
I put a voltmeter on the battery terms and got a reading between 12 and 13 volts. Where do I check from here? (by the way the positive cable and terminals are all brand new) Thanks!
Old Nov 27, 2006 | 12:22 PM
BroncoRoadKill's Avatar
BroncoRoadKill
The alternator should be charging about 13.5- 14 volts.
You can take it off and have it checked by an autozone or parts house for free.
Old Nov 27, 2006 | 12:43 PM
Kemicalburns's Avatar
Kemicalburns
time for 3g alt upgrade. check out www.fordfuelinjection.com for the alt you need along with wiring harness and fuse block. great upgrade and well worth it.
Old Nov 27, 2006 | 05:49 PM
dwoodler's Avatar
dwoodler
Try an auto electric place for rebuild parts before replacing it from a parts store. When the replacement is $130 +, I can rebuild them myself for about $60 and the only thing re-used is the windings, case, rotor, and pulley.
Old Nov 27, 2006 | 06:45 PM
BroncoRoadKill
Well hopefully its not the alt. It could just be its not getting its sygnal wire.
