Crank position sensor
Old Nov 27, 2006 | 12:18 AM
TRUE IMAGE's Avatar
TRUE IMAGE
1999 EXPLORER 4.0 SOHV
I suspect the CPS is not funtioning. Any suggestions on how to check or verify?
Also I am not able to use the search function in the forums any help there?
Thanks all.
Old Nov 27, 2006 | 12:27 AM
thefarelaneman's Avatar
thefarelaneman
best way is to have the OB11 system scaned, With this sensor if its like the cam position sensor you have the "pick up" and the actuator , If its a bad pick up the replacement and repair will be less trouble and less cost
Old Nov 27, 2006 | 12:31 AM
TRUE IMAGE's Avatar
TRUE IMAGE
thanks farelaneman but I don't understand what you mean by the "pick up" and the actuator. Can you explain?
