No 5th or reverse
Old Nov 26, 2006 | 10:17 PM
scottr408's Avatar
scottr408
No 5th or reverse
I have a 95 f150 4x4 with a 302 and the mazda 5 speed trans. Trans will not stay in fifth gear or reverse without holding the shifter. Any help would be greatly appreciated.
Old Nov 26, 2006 | 10:35 PM
Tdvjensen's Avatar
Tdvjensen
Unfortunatly that sounds like a couple of bent shift forks, or the teeth on both of those gears have been rounded off. In either case the transmission must be disassembled to fix the shift forks, and even more so for the gears. I had the same transmission in my truck and replaced it whith the ZF 5spd when I converted it to a 4x4, but I didnt pay to much attention to the case design when I removed the mazda 5spd. If you have an access panel on top, then the shift forks are usually attached to it and by removing that then you can get a good look at the shift forks to see if they are bent. This will also give you a good look at the gears and will be able to tell if they are damaged. There is an plate in the floor that the shifter comes through that is removable, but that involves removing your floor covering to get to the bolts. In either case you are looking at removing the transmission from the truck.
