pyrometer
Old Nov 26, 2006 | 08:40 PM
96powerstroke's Avatar
96powerstroke
pyrometer
is there a difference in readings for a clamp style pyrometer vs. a regular drill and tap pyrometer?
Old Nov 26, 2006 | 09:00 PM
tjbeggs's Avatar
tjbeggs
not that I have heard of but I have not experience using both. I would think not jsut mount either preturbo and you should be good to go. Either way you will be close enough to knok whether you are cooking your pistons or not!
Old Nov 26, 2006 | 09:22 PM
79F150EFI's Avatar
79F150EFI
The clamp style uses a large "radiator" clamp that raps around the exhaust piping to hold the sensor in place. People often complain of exhaust leakage with these. When putting them in the pipe, this is a common method because the pipe isn't really thick enough to tape and then securely screw the sensor in.
The drill and tap requires you to drill, tap the hole, and the screw the sensor in place. Less leakage, more permanent installation, but it takes longer.
I was originally going to just clamp my sensor on for time reasons, but now I will probably just drill and tap the exhaust manifold.
Old Nov 27, 2006 | 06:22 AM
tjbeggs's Avatar
tjbeggs
yes most people drill and tap the manifold, like you said more time and more risk (more shavings, broke bits and taps) but more secure and permanant.
Old Nov 27, 2006 | 11:23 AM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
i have mine clamped. it's been on for about 4 years / 100,000 miles. no leaks, hasn't fallen out, etc.
Old Nov 27, 2006 | 11:35 AM
1969fordguy's Avatar
1969fordguy
My pyro probe is threaded in. Tapping is easy, but either way should work fine.
Old Nov 27, 2006 | 01:22 PM
96powerstroke
what is the best way to drill and tap the manifold? i guess i am asking what is the best way to reduce the risk of lots a shavings?
Old Nov 27, 2006 | 01:54 PM
tjbeggs's Avatar
tjbeggs
I have heard many say they just drilled it tapped if and then used a vacum to suck it clean. Others have used grease on the drill and tap to stick the shavings there. Can't say from experience cause I've never done on. Just go slow. And when you tap don't run the tap all the way in, Just like half way or 3/4 of the way.
Old Nov 27, 2006 | 03:22 PM
1969fordguy
Right on with the vacum. I drilled it, then used a shopvac on it. Then I tapped it *slowly!* and sucked it out with the shopvac again. I cleaned the tap several times and it worked out really well. I also used some grease on it. The only hard part was keeping metal shavings out of your face!
Old Nov 27, 2006 | 04:27 PM
johnguc's Avatar
johnguc
Grease works on the tap real well.
I didnt use it for the pyro install.
But I needed to tap my oilpan for oil return line for a supercharger on my Corvette.
It worked good no metal got away from me.
Old Dec 1, 2006 | 07:33 PM
Texmo's Avatar
Texmo
I did mine the same way 1969fordguy did and everything worked out just fine..
mikec91
Apr 14, 2012 05:36 PM
v10man51
May 12, 2008 05:23 PM
2New2Fords
13
Sep 21, 2006 08:38 PM
pip_clark
Feb 22, 2006 10:08 PM
trencherman
Nov 12, 2004 11:27 PM
