F250 ???
Old Nov 26, 2006 | 04:52 PM
F250_help's Avatar
F250_help
F250 ???
OK this is my first posy on this Forum. I have a 1988 F250 truck with a six cylinder 300. It has a 5 speed transmision in it.
First of all what is the towing capacity of this Truck? I mean how much can it pull? I am looking to tow a tractor (John Deere 4020) that is 8,500 lbs by its self. Tractor would then be on a tandum axel trailer. Could this truck pull this?
Also,
As of right now the truck has problems running. When you start it up it runs great under 2000 RPM, but when you rev it up above that, it starts to Backfire and really bog down. When I drive it it lacks power because I can barely press the gas pedal and go. If I press it more than that, it will backfire and bog down, sort of like it is missing...Does anyone know where I need to start looking to fix this?
Thanks for you time and help
Old Nov 26, 2006 | 05:22 PM
Ranger GT2's Avatar
Ranger GT2
As for the performance part. Have you tuned the truck up? ie. sparkplugs, fuel filter, cap, rotor, air filter? Sounds like maybe it might be out of time or not getting enough fuel. Does your check engine light come on?
Old Nov 26, 2006 | 05:41 PM
F250_help's Avatar
F250_help
Check engine light does not come on. It runs GREAT right around idle, then at about barely opening the throttle (about an 1/8 of the way) it boggs down GREATLY!! and Back fires and misses and loose power. I can barely go about 20 mile an hour.
Old Nov 26, 2006 | 05:58 PM
Nick_F150's Avatar
Nick_F150
Could be the TFI module on your distributer
Old Nov 26, 2006 | 06:02 PM
F250_help's Avatar
F250_help
Really? what does that do? I am sure it is easy to replace... I will chech that..
Thanks..
Old Nov 26, 2006 | 07:45 PM
havi's Avatar
havi
I'll have the Roast Duck
tfi module is what helps in your timing. I would check for vacuum leaks, especially those skinny lines up by the back of the valve cover. They're prone to cracking. Another option is to have your maf sensor tested.
Old Nov 26, 2006 | 07:56 PM
Nick_F150's Avatar
Nick_F150
well everytime the tfi goes out on my pick-up those are the symptoms but now i have a 81 duraspark ignition now so no more tfi probs..
Old Nov 26, 2006 | 09:29 PM
F250_help's Avatar
F250_help
Nick_F150, havi,
Thanks so much for the help with this. I will try thoes both, first I will try to check the TFI then I will look for more vacume lines...
thanks, any one else?
Anyone know what this truck is capable of pulling as far as trailer weight?
Old Nov 26, 2006 | 10:44 PM
Argo's Avatar
Argo
Is it a light duty 250 (under 8600lb GVWR) or heavy duty 250 (over 8600lb GVWR)? You can tell by looking at the rear axle. If there is a protrusion from the rear axle hub at the center of the rear wheels that has bolts around it, you have a full floating axle, so it is most likely a heavy 250, with a GVWR of over 8600lbs.
Old Nov 27, 2006 | 07:12 AM
Ranger GT2's Avatar
Ranger GT2
Is there still a sticker on the door or door jam that tells the GVWR? That may help identify what your truck is capable of?
Old Nov 27, 2006 | 10:33 AM
F250_help's Avatar
F250_help
OK dummy question, what is GVWR? How does that translate into how much I can actually tow, or pull? Is GVWR the amount that the bed it self can hold?
Thanks for this info, its a great start for me. I will try to look for what you described..
Old Nov 27, 2006 | 10:34 AM
F250_help's Avatar
F250_help
I will look for that..
poffutt
1978 - 1996 Big Bronco
32
Nov 24, 2022 01:45 PM
areoseek
26
Sep 25, 2013 05:30 PM
FordTroutCatcher
Aug 5, 2012 08:08 PM
Psycho_bob_1977
Apr 24, 2004 12:53 PM
rusty78
Sep 15, 2003 01:21 PM
