flywheel question please help
Old Nov 26, 2006 | 02:15 AM
moose94's Avatar
moose94
Will a flywheel from a '94 302 f150 fit a '89 351w? Any help would be appreciated thanks.
Old Nov 26, 2006 | 10:49 AM
moose94's Avatar
moose94
Does anyone know?
Old Nov 26, 2006 | 11:57 AM
dinosaurfan's Avatar
dinosaurfan
flywheels
Moose, yes, it will fit- IIRC. The other part of my bad memory doesn't remember if the balance is the same, however. Maybe the Fellows in the 289-302-351W forum can help. DinosaurFan, on the work 'puter
Old Nov 27, 2006 | 11:58 AM
gustang818's Avatar
gustang818
While it will fit, the balance on a '94 302 is 50 oz and the 351 is 28 oz. You need to use a 28 oz flywheel on the 351 to avoid problems. A machine shop can re-balance the flywheel but it may be just as cheap to get another with the proper balance.
