diesel conversion
Old Nov 25, 2006 | 10:31 PM
19754d00r's Avatar
19754d00r
diesel conversion
I recently purchased a 1975 f-250 four door four wheel drive with a 4 speed and a 360 I want to convert over to a 6.9 or 7.3 with an after market turbo or find a powerstroke. i would like a 5 speed, but i found a rebuilt c6 for cheap. my only concern is i need some higher gearing in the transmission to help with freeway travel. will a c6 help and any other suggestions before i begin thanks
Old Nov 25, 2006 | 10:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Old Nov 26, 2006 | 08:55 PM
68Mercury250Ranger's Avatar
68Mercury250Ranger
It will fit without much difficulty,Highboy crossmember has more room than the lowboy. You should maybe look for a 6.9 flywheel/clutch/bellhousing to mate up to the 4spd as you will need tall gears to make up for no overdrive and the 4spd would give you decent start off instead of the C6.
Old Jan 26, 2007 | 09:36 PM
clunker86's Avatar
clunker86
i beleive there is more ot there to offer to convert a gas to diesel then diesel to gas. there is just a lot of wiring that you will need. i would pull the whole harness from anoth 6.9 or buy a complete wiring harness. good luck
