Scanner
Old Nov 25, 2006 | 07:11 PM
Maddcatter's Avatar
Maddcatter
Scanner
I have a 1997 f250 powerstroke. I would like to get a scanner I can use on the diesel and my car. I tried a Actron from autozone and nothing came up on the scanner, no screen at all. Of course the guy couldn't tell me if the scanner supports diesels or not. No one seems to know whats the problem.
Old Nov 25, 2006 | 07:18 PM
1997F-350's Avatar
1997F-350
those ones dont work. they got to be ford enhanced.
get a auto engenuity or ease that will work on fords and your make of car. easy to use especially if you got a laptop. i use the ease. never tried it on another vehicle but i am sure it works.
obd2.com
Old Nov 25, 2006 | 07:21 PM
IDMooseMan's Avatar
IDMooseMan
I don't have a scanner, myself, and you just stated the reason why. If they can't tell you for certain the scanner will work on a diesel, it probably won't.
I have seen some scanners at Napa and other auto parts stores, some stated, on the label or the "vehicles supported" section, that they work with diesels.
If the screen is blank, and the scanner batteries are good, I'm thinking the scanner doesn't work with diesels.
Get your money back, unless you need it for another vehicle.
Old Nov 26, 2006 | 11:43 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE Maddcatter.
Generally the diesel specific codes are not supported by the....less expensive scan tools. The software available for laptop and palms gets good reviews here, and the high end diagnostics like a Rotunda NGS or Snap-on scan tools also work.
If you get a performance programmer like Superchips SCMT, it will scan your truck and any other Ford, but I don't think it will do anything but generic codes on off brand OBDII systems.
