Offroad & 4x4
4WD, Front end question
Old Nov 27, 2006 | 10:06 PM
chrono4's Avatar
chrono4
you say that now, but wait till you get stuck and need them......................................
Old Nov 27, 2006 | 10:23 PM
nobodyspecial's Avatar
nobodyspecial
That is a very good point, but if you look back, you will see my previous post about finances and the wifey needing all of her sparkly stuff, so since technically they are working, and the only thing I should have to deal with is snow storms, and county/city workers not getting the roads clear in time, I think that they should suffice for this winter, and this spring I will put some manual hubs in before the off roading season starts.
btw, I have heard good things about Warns premium hubs. Who has them, and what do you think about them?
Thanks!
Old Nov 28, 2006 | 01:27 AM
khadma's Avatar
khadma
Carpenter Local 745
Most 4wd shops either have them or can get the hubs for you. I like to support locally owned and operated shops and give these shops my business first before I order from larger corprate outfits, that's just me. Do what is easier and more affordable for you.
I think Warn invented the lock out hub years ago. I prefer Warn, but there are also other companies that make manual hubs. I will suggest Warn since I use them.
Do not forget to reverse at least ten feet to unlock your auto hubs, sounds like you did not back up far enough in previous attempts!
Old Nov 28, 2006 | 01:29 AM
nobodyspecial
Ok, yeah, didnt know about the ten foot thing, it was probably about 5 feet that I backed up, will make sure I do that in the future!
Old Nov 28, 2006 | 01:40 AM
khadma's Avatar
khadma
Carpenter Local 745
A 30 inch diameter tire has a roll out of about 9 feet more or less. 5 feet may not get the tire all the way around.
Old Nov 28, 2006 | 01:41 AM
nobodyspecial
I see, I didnt realize that it needed to go all the way around, but now, thinking about it, it makes sense
daaper2k05
16
Dec 24, 2018 04:42 PM
67rangerxlt
2004 - 2008 F150
Jul 25, 2011 01:28 PM
jc8825
Oct 4, 2010 11:38 PM
96f150
1997 - 2003 F150
Dec 23, 2007 12:43 PM
ykhanna
Dec 18, 2003 06:50 PM
