Diff leaking ?
Old Nov 24, 2006 | 02:40 PM
dean307's Avatar
dean307
4x4 ?
I had to replace a u joint on the front driverside wheel, after replacing I change the oil in the front diff. The other day before I pulled it out of the garage I notice some diff oil on the garage floor under the u joint just repaired. After a short 3 to 4 mile trip I noticed some more leakage in the same spot.
Is there some seal I did'nt notice to replace or did I just over fill the diff. ?
The leakage is not excessive, and I don't drive the truck offen, so I don't know if this is a real big problem, or almost nothing at all.
Thankyou for your help
Vince
Old Nov 24, 2006 | 03:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Nov 24, 2006 | 05:19 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Exclamation
Sounds like your pinion seal is leaking.Unless you have the proper tools to do the job i'de leave it to a professional.
Old Nov 25, 2006 | 01:55 PM
wickymustang's Avatar
wickymustang
Crawl under there and look. Is it coming from the pinion shaft of the front drive shaft or is it coming out the axle tube?
Old Nov 27, 2006 | 10:56 AM
dean307's Avatar
dean307
Wickymustang, the leak is coming from the axle tube, I replace the u joint on the front right wheel. The whole axle came out, I replaced the u joint the reinstalled the axle, I don't remember any seal, but the axle was out for about 3 months while I got around to replacing the joint before I put it back together....
Vince
