Sponsored by: Innova
wireless headphones 03 Excursion
Old Nov 24, 2006 | 12:51 PM
thesixcar's Avatar
thesixcar
is there anything i can do about the large oversight ford made by not offering wireless transmitters in the 03 excursion??? i am less than amused at the options i have now. please help shed some light. do i need a monitor from an 02,04,05??? am i stuck with a cousin eddy approach to screwing shizzle into my headliner and running wires from here to there? there has got to be a better way.
Old Nov 24, 2006 | 11:33 PM
ReAX's Avatar
ReAX
I have delt with a company in central FL, and thier wireless headphones were seperate from the head unit. Autocinema.
Most all of the video companies should have a non-intregrated wireless system you can add to the audio out put and power.
Old Nov 24, 2006 | 11:38 PM
thesixcar's Avatar
thesixcar
i have seen many that require screwing a xmitter into the headliner and/or routing power and and audio down the pillar. i want a factory looking solution to my dilema. thanks for the tip.
Old Dec 3, 2006 | 09:58 AM
cln2po's Avatar
cln2po
Look for an RF headphone system. I know Un-wired and other companies make them. They use an outboard RF transmitter rather than a IR system so they dont need 'line of site' to function. The transmitter can be mounted virtually anywhere. Most good install shops should be able to handle the intigration to your factory system.
http://www.unwiredtechnology.com/cgi...D=PUT_SID_HERE
Good luck!
Nelson
swarf_rat
6.7L Power Stroke Diesel
26
Dec 27, 2016 06:53 PM
BCM
Mar 25, 2015 01:53 PM
ExcursionTime
Dec 30, 2010 10:37 PM
builtfordtough13
Feb 14, 2008 04:36 PM
ExcursionDad
Nov 26, 2006 08:34 PM
