Quick fuel pump question
Old Nov 26, 2006 | 07:05 PM
true blue's Avatar
true blue
I am not really sure where it is that you are talking about. Is it inside the banjo bolt or in the back on the heads?
Old Nov 26, 2006 | 08:08 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Sorry man- It's the back of the heads. The banjo bolt holds down a fitting that has two steel lines coming off of it. Each steel line runs to the back of a head. Where the fitting connects the line to the head it looks like a compression fitting, but when you open it up there is no ferrule inside, just a rubber sleeve that goes around the tubing and the nut compresses it inside the fitting.
I've probably seen as many fittings as the next guy but I don't recall ever seeing this kind of fitting anywhere else. The passenger's side is a PITA and you may want to loosen the downpipe to get to it easier.
Old Nov 27, 2006 | 06:52 AM
true blue's Avatar
true blue
I don't see anything leaking there. I sure hope I do not have to replace those.
Old Nov 27, 2006 | 08:16 AM
1996pwrstrk's Avatar
1996pwrstrk
Thumbs up
I used the fuel pump from autozone when I did mine no problems yet .I did shim the fpr to get the fuel pressure up from 55 psi but that's it.
Dave
