Track Bar Problem?
Old Nov 23, 2006 | 12:46 PM
kneelix's Avatar
kneelix
Track Bar Problem?
I am having trouble with a wobble in my 76 F150 4WD. I believe its known as "death wobble". Even when my truck is off and sitting there is definitely a noticeable problem. The hood buckles when I move the wheel one direction and not the other. I got under the truck and it seems the only thing it could be is the track bar. I believe it is in the bolt that mounts the bar to the front axle. This bolt has play in it. Could this be the sole cause of my terrible wobble? Also, is the bolt hole sleeved could this have worn out and how can I fix this problem? Any help would be appreciated.
Old Nov 23, 2006 | 01:39 PM
Mil1ion's Avatar
Mil1ion
You can buy new bushings and install them ..even without removing the coil springs.
Old Nov 23, 2006 | 06:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
The hood buckling may indicate bad body mounts also.
Old Nov 23, 2006 | 07:44 PM
timothy47129's Avatar
timothy47129
Its the track bar.Mine did the same thing.When you go the get replacement bushing make sure they give you the right thing.No parts store around here knew what track bar bushings were.They all told me they call them radius arm bushings.lol they should run about $12.00-$15.00
Tim
Tim
Old Nov 23, 2006 | 11:55 PM
Mil1ion's Avatar
Mil1ion
That's because they are called: radius arms
not track bars.
Old Nov 24, 2006 | 11:11 AM
timothy47129
I think he is talking about the bar that runs parelle with the axle from the axle to the frame.Which would be the track bar or track arm.
Tim
Old Nov 24, 2006 | 03:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
With a solid axle he would have a track bar. Get poly bushings for it for better steering and control.
Old Nov 24, 2006 | 06:41 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
Energy Supsension, they have the radius-arm Bushings, the C-bushings (for the radius-arm to axle) AND the track-arm bushings, I think the whole she-bang was under $40 from 4wheel parts. I just did this on my 77, makes a TREMENDOUS difference, note to self,,,, unbolt the radius-arm brackets from the frame BEFORE you attempt the C-bushings.
6ohman2004
13
Aug 29, 2014 09:01 PM
Jayman1976
Dec 15, 2013 09:45 PM
built tough
Dec 7, 2011 11:23 AM
cadunkle
17
Jan 23, 2009 03:58 PM
79F150400M
Aug 4, 2005 09:32 PM
