1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Adding factory back up sensors
Old 11-23-2006, 10:08 AM
rms911's Avatar
rms911
rms911 is offline
I have a 2006 Expedition EB and want to add the back up sensor system. Is the vehicle prewired? Can I add the system easily or should I buy an aftermarket? Thanks.
Old 11-23-2006, 05:47 PM
FTE Herman's Avatar
FTE Herman
FTE Herman is offline
Welcome RMS911! I have the back up sensor in my Navi and glad I have it. Sadly, I have no idea whether it is a simple add on or not, although I think you might need to add the console switch that turns it of when backing a trailer, also, I don't know wher ethe beeper is. Anyhow, hopefully someone with a bit more knowledge migh chime in.
Old 12-21-2006, 07:03 PM
Trucker22's Avatar
Trucker22
Trucker22 is offline
wiring
My 2000 Nav was prewired---the defeat switch wiring is in the center between the two front seats. Then there is wiring in the pillar just behind the right rear pass door. I didn't want to pay what the dealer wanted for their system so found a $30 system at Kmart in Illinois and installed it. Put two sensors on the bumper and the beeper on that pillar and a defeat switch by the drivers seat. Works great except useless in cold weather---the Kmart unit is not suitable in cold weather. But for the money it was a bargain. I suspect the wiring exists in your truck too as it's an not a std option so they usually put the wiring in = just not the components unless you pay for it.
jomoflymo
08-15-2015 12:36 AM
welbo97
13
01-26-2015 09:39 AM
woody367
1999 to 2016 Super Duty
11-13-2014 05:00 PM
tcjhkbjt
02-10-2014 09:02 AM
renyren
13
05-16-2010 11:10 AM
Quick Reply: Adding factory back up sensors
