Fast Flashers?
Old Nov 22, 2006 | 11:11 PM
ftcav's Avatar
ftcav
Fast Flashers?
I have a '94 F150 4x4 with 4.9l I6 and manual transmission. My turn signals have started acting funny. When I push the lever to turn left or right, the signal starts normally with the "blink - blink - blink" noise and at a normal flashing pace. Then the blink/click noise stops and the flashing speeds up. Can someone tell me what I need to fix?
Old Nov 22, 2006 | 11:29 PM
95X15's Avatar
95X15
Replace the turn signal flasher first.
Does it doe the same thing with the emergency flashers?
The load in the circuit will affect the speed of the flashing - if you hook up trailer lights with a standard flasher (2 bulbs) the trailer will add a bulb and total 3 bulbs causing rapid flashing.
Old Nov 22, 2006 | 11:34 PM
McLeod's Avatar
McLeod
I think his vintage has a separate flasher for the emergency flashing.
Old Nov 23, 2006 | 12:08 AM
Rusty_Spurs's Avatar
Rusty_Spurs
My 1996 F250 did the same thing. I changed the flasher unit and it fixed the problem. Yes their is 2 seperate units on it, the flasher relay in on the backside of the fuse box. Crawl underneath the dash and you will see it. This will fix your problem.
Old Nov 23, 2006 | 06:05 AM
Leader's Avatar
Leader
both flashers are the same, just switch them to see if that is the problem.
Old Nov 23, 2006 | 06:59 AM
frederic's Avatar
frederic
I have electronic flashers in my crewcab... they flash at the same rate whether there are the body blinkers only, or trailers, or overheads attached, or all three.
And because I hate how they sound, I shoved a cotton ball into each of them and covered with electrical tape.
Old Nov 23, 2006 | 10:02 PM
ftcav's Avatar
ftcav
Thanks!
There are two flasher units - one for the turn signals and one for the hazards. I switched them and the turn signals work again. I'll replace the bad one tomorrow. Thanks for the help.
