Sponsored by: Real Truck
4WD vacuum switch
Old Nov 22, 2006 | 01:11 PM
sonicblue2003's Avatar
sonicblue2003
4WD vacuum switch
I have had problems with my auto/manual hubs,so I did some research on here and found some interesting stuff. So I have dissasembled them ,cleaned and lubed as explained. Ok so now that that is done I thought I would check the vaccum at the hub. Well there wasn't any when it was running. So I traced everything back to the switch on the RF fender. I put a gage on the port with the supply still hooked up and when I swich into 4WD high or low I get vacuum.
Heres the question I have. How long should the vacuum stay applied to the hubs. Mine quits after about 30 seconds. Does this mean something is wrong with a relay or is this normal??? If you lose vaccum wont the hubs disengage?
I didn't stand there and wait for more than a couple of minutes to see if there would be another pull of vaccum but i need to know what to expect and what to look for.
Thanks in advance.
Old Nov 22, 2006 | 01:56 PM
biz4two's Avatar
biz4two
Arrow
Nope your vacuum actuator is performing normally. If you have no vacuum at the hub, then it must be between the hub and the vacuum actuator...IMHO.
The vacuum actuator will provide the initial pulse of vacuum, then it will turn off. It does not continue to provide vacuum to the hub. The hub should lock and remain locked until the ESOF switch is turned to the 2HI position...then again the vacuum actuator sends a pulse to the hub and disengages the hub.
Hope this helps...and makes sense.
biz
Old Nov 22, 2006 | 04:34 PM
sonicblue2003
Ok. So what you are saying is that it only needs to engage and the plastic thingy (for lack of the correct term) locks and hold it there until it ratchets and allows full return with the next pulse?
The reason I had no vacuum at the hubs is, by the time i got in and out of the truck,it had already shut off. DUH!!! I'm blonde!
Thanks.
Old Nov 22, 2006 | 05:36 PM
2012 SD Snowbuster's Avatar
2012 SD Snowbuster
I have a similar question.. I slid off the road and switched the selector to 4hi and the truck didnt engage, result rear tires spinning and diggin up the grass. Shifted from reverse to drive, to rock it and still no 4 wheel. The Powerstroke is just diggin some more. I still had no 4wheel after 2 more trys and then just ripped the side of the road up. Once I got back on stable ground I pulled off to the side(gravel) and flipped the switch.. bingo 4 wheel light on dash and no spin...what gives?? I have had 4 other 4x4's and none had this shift on the fly crap switch I had a shifter on the floor. I pulled back and it was in...no maybe it's in I knew it was in.. Can somebody enlighten this oldschool 4x4er?? I love the 04 but hate this ESOF stuff so far.
Old Nov 22, 2006 | 06:51 PM
LP2's Avatar
LP2
I couldn't agree more. Give me a part # for the floor lever please!
Old Nov 22, 2006 | 07:14 PM
sonicblue2003
Exclamation
Also take note for you ESOF guys. When you put the selector in 4HI you get a slow vacuum apply(takes 5 to 10 seconds for full vacuum). But if you put in 4LO you get instant vacuum.whatever amount you have at the manifold.
I guess that is so you don't get a bang when it engages at 50mph.
Old Nov 23, 2006 | 12:11 AM
biz4two's Avatar
biz4two
Arrow
Thanks.
It would be better with a second set of hands.
biz
Old Nov 23, 2006 | 12:13 AM
biz4two's Avatar
biz4two
Arrow
Not really sure why it engaged on the second try, but the ESOF must be switched when "On the Fly"...or moving. That is why FORD also includes the ability to manually LOCK the hubs...just in case you are already stuck.
biz
phillycincykid
Feb 20, 2014 06:11 PM
w74bronco
Feb 9, 2014 12:40 AM
erichy
Oct 23, 2011 05:49 PM
wildwheelerb200
Apr 4, 2010 12:08 PM
drtire
Mar 22, 2008 08:43 AM
