explorer problems
Old Nov 26, 2006 | 01:42 PM
aquanaut20's Avatar
aquanaut20
I am confused as to why you think just randomly throwing $$ in parts at it will fix the problem, without doing basic diagnostics.
I inquired a week ago as to the colour of your plugs, did you pull a cple?
Old Nov 26, 2006 | 01:56 PM
screamin's Avatar
screamin
I replaced the plugs, they all looked good they were a light brown in color
Old Dec 2, 2006 | 11:54 AM
big wind's Avatar
big wind
code 173
I just had my 92 back from the shop yesterday and I too got this code-they said it is the vacuum modulator on the transmission-after I replace this I then need to replace all the vacuum lines since they likely are causing vacuum leaks from trans fluid degredation-my weekend project! Hope it helps you...
Old Dec 2, 2006 | 05:21 PM
screamin's Avatar
screamin
Let me know how it turns out, do you know why they say its the vacuum modulator??? good luck
Old Dec 2, 2006 | 06:42 PM
MisterCMK's Avatar
MisterCMK
screamin, have you checked your fuel pressure? Cleaned your injectors?
Old Dec 3, 2006 | 08:01 PM
MrSki's Avatar
MrSki
screamin
Email me your phone number and I can help you. Too hard typing words to really understand the issue. My email is mrski at *** dot net no spaces.
Old Dec 3, 2006 | 08:09 PM
screamin's Avatar
screamin
will do...Thanks
KeithAP
Apr 12, 2010 05:51 PM
ramour2
Aug 31, 2005 09:16 AM
Heated
Nov 20, 2004 11:12 AM
Webslinger
Oct 13, 2003 11:09 PM
Elk_hunter
Jun 6, 2002 11:57 AM
