Help...Engine problems...Time crunch
Old Nov 21, 2006 | 01:03 PM
mr_malina's Avatar
mr_malina
I am at work right now and I was going to lunch and discovered oil spattered on my fender. I did some looking around and the crank breather hose had popped out of the airbox and oil mixed with yellow sludge was coming out. I checked my oil and its quite low and has yellow sludge/oil in it. Dipstick is rusty too. I just changed the oil about a month ago and probably put 500mi on it since then, when I changed it I did not notice anything unusual.
I am not sure what has happened. Please help.
Old Nov 21, 2006 | 04:25 PM
compaddict's Avatar
compaddict
Yellow sludge.. First thing is check your coolant level and taste the sludge and see if it's sweet. If it tastes sweet you have coolant mixing with your oil some how.
Vince
Old Nov 21, 2006 | 04:34 PM
mr_malina's Avatar
mr_malina
My coolant level is normal and I am not tasting the engine sludge.
Old Nov 21, 2006 | 05:09 PM
quicklook2's Avatar
quicklook2
mmmmm mmmmmm mmmm!
mc sludge for lunch.
hahahahaha
Ranger GT2's Avatar
Ranger GT2
Do you have to drive very far to get to work? Does the engine get fully warmed up before getting there? Has the engine been running any different?
Old Nov 21, 2006 | 05:30 PM
compaddict's Avatar
compaddict
I guess you could buy a test kit to know for sure (if you don't feel like taking a taste yourself). At any rate, I would KNOW if I had AF in the oil before doing any other troubleshooting.
One more thing, engine oil sludge is not the same as toilet sludge. I mean I wouldn't chew it down and eat it, but a trace on your tounge will tell alot in less than a second.
Vince
Old Nov 21, 2006 | 06:05 PM
mr_malina's Avatar
mr_malina
Engine gets warm. Engine was running the same as allways. I have to drive 31 miles to work.
Old Nov 23, 2006 | 12:33 PM
compaddict's Avatar
compaddict
So, did you test for AF?
Vince
Old Nov 23, 2006 | 04:49 PM
mr_malina's Avatar
mr_malina
Vince
I have not had a chance to test it yet.
P.S. I didnt take the chance and had the truck towed home.
Old Nov 23, 2006 | 04:52 PM
compaddict's Avatar
compaddict
Anti-freeze
Vince
Old Nov 23, 2006 | 06:14 PM
1982fordf100's Avatar
1982fordf100
Sounds like the yellow sludge is blow by from the cylinders. The reason the crankcase breather popped out was because of the crankcase pressure from the blow by. My 82 F100 had alot of blow by and some loss of power before I rebuilt it. I ended up finding two broken compression rings and a worn pistion ring groove. It was my number 5 cylinder which only had 90 psi. Does the yellow sludge happen to smell a bit like fuel? I know it did on my 82. Do a compression test to check for worn rings. If you have a few low cylinders it probably has some worn or broken rings. What year is this 300 and how many miles are on it? If you drive 31 miles to work that is plenty to get everything hot. So its not some condensation.
Old Nov 23, 2006 | 06:32 PM
mr_malina's Avatar
mr_malina
Its a 91 and it has 133,xxx. I would only drive it to work every few days. I am going to do a compression test in a couple days.
