Radiator
Old Mar 8, 2002 | 10:30 AM
truckzilla's Avatar
truckzilla
Radiator
Old May 31, 2002 | 02:13 PM
58ford's Avatar
58ford
Post Radiator
Well HOwdy once again to you all!!!
I just turned in my radiator from my 58 f100 223 into a shop and it was shot! They are going to look for another one for me but if they can't find one I need some leads. can anyone help? Thanks Yall---jax
Old May 31, 2002 | 03:32 PM
hirschi's Avatar
hirschi
Radiator
If it's a shop, can't they build you one out of a core?
otherwise... I know LMC truck sells them and I'm sure others do too.
Good luck.
James
Old May 31, 2002 | 04:15 PM
pcmenten's Avatar
pcmenten
Radiator
Regarding LMC truck; I ordered some parts from them, small simple parts, and they sent the wrong stuff. I will be avoiding them in the future.
Regarding the radiator; I just got my radiator back from a real, old tyme radiator shop (Fry's Radiator in Boise, Idaho). My heater core is getting reworked as I write this. This is at least the fourth and fifth job they've done for me.
I spoke to them about a radiator for my '55 Chevy. The core was shot. They said they could install a heavy duty two, three, or four core using the original tanks. It would cost about the same as buying a new radiator. That's the kind of thing a real radiator shop does. (BTW, they explained 'heavy duty' as a type of core that has ridges inside the tubes to increase the wetted surface area inside the core. Extra cooling.)
My heater core? It was shot, so they said they would use the original tanks and install a new core in that! A new heater core costs $100 to $125 mail order.
Best of luck,
Old Jun 1, 2002 | 09:57 AM
wosborn's Avatar
wosborn
Radiator
Lots of catalogs list the replacement radiator same as stock. An interesting alternative I read about somewhere (here?) was swapping a full-size mid-70's AMC Ambassador or Matador radiator. I think this is a more efficient cross-flow style, and reportedly slips right in. Anybody heard of this one? Seen it in action?
Old Jun 1, 2002 | 10:15 AM
51f1's Avatar
51f1
Post Radiator
[updated:LAST EDITED ON 01-Jun-02 AT 11:16 AM (EST)]I don't know how it would work for your truck but, in my '51 w/302 I installed a radiator from a full size Dodge van. Dropped right in, inlet, outlet and tranny lines right where they needed to be. $70.
Good luck & have a fun run!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
