Bent Rods
Old Nov 20, 2006 | 10:53 PM
Kongslibakken's Avatar
Kongslibakken
Bent Rods
I have a 351 cleveland and it runs fine its been sitting for several years and only run ocasionally pulled the intake today it appears like one of the rods is sligthly bent but it hard to tell the way they sit. How noticable would it be if it was would it affect the way the motor runs ??? Also I'm replacing the pan with a rear sump pan from a junkyard the inside of the pan is rusted are there any ill affects to sandblasting the inside of the oil pan. Any other options ?
Old Nov 21, 2006 | 12:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
Pushrod or piston rod?
Find out what made it bend, then take the engine apart, replace the necessary parts, clean it, and reassemble. Remember to run diesel engine oil and treat it just like you were breaking it in all over again.
Old Nov 21, 2006 | 07:35 AM
Kongslibakken
push rod I'll have to look today Thanks
Old Nov 21, 2006 | 09:48 AM
beartracks's Avatar
beartracks
Check to be sure all the pushrods are properly seated in the lifters and rockers. I would take them out and roll them on a piece of glass to check for bends. Depending on your heads the valves may or may not re adjustable.
Old Nov 21, 2006 | 03:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
Spring bind, bent valves, improper preload, etc, can cause bent pushrods.
Old Nov 21, 2006 | 10:32 PM
Kongslibakken
Guys I pulled the rods and they are OK everything looks pretty good this should save me some change. Now its on to blast my pan and seeif the motor fits. Thanks Bak
Old Nov 21, 2006 | 11:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
Still need to find out why that pushrod bent so it won't happen again.
Old Nov 22, 2006 | 10:50 PM
Kongslibakken
Torq the rod wasn't bent I think it's just my eyes and old age. Thanks Again
Old Nov 23, 2006 | 12:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
CSS AND CRS??? Man you are getting OLD like me...
