New Transmission Problem
Old Nov 20, 2006 | 08:59 PM
Akautman's Avatar
Akautman
I have a 97 f-250 powerstroke with 244,000 miles on it. 5 months ago i went to dennys transmission shop in phoenix, az. my transmission was messing up and the overdrive light was blinking so i figured it needed a new transmission. Well he said i did so i bought a rebuilt transmission for $1600 and he replaced it. Well since he's finished it i've brought it back to him 6 times and he never fixes the problem that is happening now. When the truck is cold it shifts fine. but once it starts getting warm it starts shifting hard. And after 30 min or 1 hour of stop and go driving, it will get stuck in first gear and i'l have to punch it or let off the gas for it to shift. and it'll happen only once or twice while i'm driving. That tranny shop won't fix it so i'm trying to figure it out for myself. please help me.
Old Nov 21, 2006 | 05:05 AM
trike1946's Avatar
trike1946
There are rebuilds and there are rebuilds. Do you know just what the trans shop did? There is one around here that says they rebuild, but don't touch the valve body at all.
Old Nov 21, 2006 | 11:58 AM
MADVAN's Avatar
MADVAN
Sounds like a valve body.
Go here brian has a good VB.
http://www.brianstruckshop.com/index.html
Old Nov 21, 2006 | 04:12 PM
Cuda_jim's Avatar
Cuda_jim
Take it to a different tranny shop and have it scanned. Most will do it for free. Sounds like your tranny is going into 'Limp in mode'. It increases fluid pressures to stop slippage and doesn't allow it to shift past 2nd gear.
Do you have a trans temp gage? It may be getting hot or could be as simple as the TFT (trans fluid temp) sensor gone bad.
Old Nov 21, 2006 | 04:24 PM
MADVAN's Avatar
MADVAN
If it was in limp the od light would flash.
Old Nov 21, 2006 | 04:39 PM
helifixer's Avatar
helifixer
sounds like they sold you a trans from phoenix retrans aka phoenix hard parts. if so your life is only starting to get bad.your only hope is to have a reputable shop overhaul it for you
