Dead 6.0 Any Ideas?
Old Nov 20, 2006 | 08:55 PM
JLHOG1's Avatar
JLHOG1
Dead 6.0 Any Ideas?
I have an 05 KingRanch w/ 52k miles. Running strong as ever, no chugs, or smoke, nothing out of the ordinary. I am 1 block from the house and it quits. Stops running w/ no warning, and will not start. Great power for turn-over but no bang at all. Towed to dealer yesterday, they worked on it all day today. No codes thrown and the FORD Master minds havent a clue. They stated they will start tearin down the engine tomorrow.
Any thoughts?
I tell ya fellas...........if Ford would use Cummins, they would have a seller! I took a chance in this purchase but..........
I had 3000 miles and they had to drop the tranny to fix an oil leak. Next the turbo went south at 20k. Its been pulling to the right since new, you wouldn't believe how many times I have been back for that.
Never had a prob w/ my 2000 Cummins 2500. I love this F250 but DANG!
Old Nov 20, 2006 | 09:43 PM
blackhat620's Avatar
blackhat620
JLHOG1,
First off find a new dealer with a "Qualified & Certified" 6.0 tech. Sounds like the guys where you are going don't have a clue.
More than likely there is a leak at the Hpop fitting. They need to diagnose it for this before they start tearing things apart.
Hope this helps
Old Nov 20, 2006 | 09:48 PM
mrxlh's Avatar
mrxlh
Go trade it in on a Dodge with a Cummins in it. You will be much, much happier.........So will we.
Old Nov 21, 2006 | 06:08 AM
JLHOG1's Avatar
JLHOG1
mrxlh,
Your point?
Old Nov 21, 2006 | 08:46 AM
a-rod's Avatar
a-rod
Id rather drive a 6.0 with problems than a dodge
Old Nov 21, 2006 | 08:59 AM
kw5413's Avatar
kw5413
Originally Posted by JLHOG1
mrxlh,
Your point?
If you are looking for help / advice you would have better success by leaving out the cummins praise here at a Ford Enthusiasts site.
Check out our newly revived 6.0 Tech folder. May be some help there for you.
https://www.ford-trucks.com/forums/3...ch-folder.html
Not sure if our resident techs can help you much since it just quit without warning or symptoms.
Old Nov 21, 2006 | 10:50 AM
JLHOG1's Avatar
JLHOG1
Learned my lesson........I'll just read for now on and not post with all the touchyness around here.............
mrlxh can post about tires and not have probs.......who cares, there are 400 posts about tires.
I had a real prob and wanted some expert opinions. Done.............
Old Nov 21, 2006 | 12:35 PM
vloney's Avatar
vloney
If they will do high pressure oil diagnostics, they will probably find either a blown out o-ring on an injector, or the hpop fitting has failed.
Old Nov 21, 2006 | 12:46 PM
kw5413's Avatar
kw5413
If you want help...chill out....there are lots of experts here. If you just want to complain and campaign for cummins...then be done.
Trying to help you here.
vloney offers a good points. Are there any symptoms, at all, that you can provide? And do you have any mods...like a programmer?
Old Nov 21, 2006 | 01:00 PM
JLHOG1's Avatar
JLHOG1
It was a high pressure coupler on the rear of the engine. I guess Ford has re-designed these.
Brrrrrrr
Old Nov 21, 2006 | 01:04 PM
vloney's Avatar
vloney
Brrrrrrr
yeah, thats the fitting I was talking about. When it goes, it just shuts 'em off. Good you got it fixed!
Old Nov 21, 2006 | 01:11 PM
JLHOG1's Avatar
JLHOG1
vloney,
Thank ya, Sir......
Old Nov 21, 2006 | 01:24 PM
Mustangdriver's Avatar
Mustangdriver
Don't let a couple guys getting off topic scare you away. When it comes to personal preference between engines, it can get pretty heated. Give this thread a little time and some guys with a lot of experience will find you. Good luck.
Matthew
jjsj38
Ford vs The Competition
19
Jun 6, 2010 03:28 PM
bczolone
Jul 25, 2009 10:56 AM
pelletman
17
Jan 27, 2009 08:08 PM
GoldF250
Apr 24, 2006 08:24 PM
bronco351
86
Sep 26, 2005 11:15 PM
