I can't remove ...
Old Nov 20, 2006 | 05:56 PM
supadupadennis's Avatar
supadupadennis
I can't remove ...
the instrument cluster in my '78. I took out all the screws but I can't seem to disconnect the main wire connected to the back of the cluster. It's a weird connection, need some help
Old Nov 20, 2006 | 06:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Do you mean the speedometer cable or the wires?
Old Nov 20, 2006 | 06:11 PM
supadupadennis
speedometer cable
Old Nov 20, 2006 | 06:42 PM
highboy1975's Avatar
highboy1975
theres a screw that holds it in. take the screw out and move the clip out of the way.
Old Nov 20, 2006 | 07:22 PM
Greg 79 f150's Avatar
Greg 79 f150
On my 79 I just had to squeeze the connector hub on the cable where it pushes in to the instrument panel, and just pull backwards on it. Never done a 78 speedocable, I would think it would be the same tho,
Old Nov 20, 2006 | 07:30 PM
supadupadennis
good stuff guys. i guess the connector hub was just a little stiff. i had to put some muscle into it
Old Nov 21, 2006 | 08:06 PM
Mil1ion's Avatar
Mil1ion
This thread was 1 page away.
https://www.ford-trucks.com/forums/5...edo-cable.html
Old Nov 21, 2006 | 08:17 PM
dean307's Avatar
dean307
Sometimes a little muscle is all you need.....
Old Nov 23, 2006 | 08:23 AM
George Frasier's Avatar
George Frasier
Just a thought - put a small bit of greese on the connection before putting it together. I use white lithium < the stuff used for boat trailer bearings.
Old Nov 23, 2006 | 10:26 AM
arctic y block's Avatar
arctic y block
I use White Lithium pre lube on all Engine and Gear box rebilts. Is this the same stuff? I use STP bearing grease on all wheel brg,s.
Old Nov 25, 2006 | 12:46 PM
George Frasier
arcticyblock - Sounds like the same "stuff". We use it at work (spray can) for the pigtails between tractor/trailer connections too. Also works on battery posts. Geo.
Old Nov 25, 2006 | 02:46 PM
arctic y block
Thanks. I use it on connectors as well. but always felt it was to lite for bearings.
Old Nov 26, 2006 | 12:53 AM
George Frasier
arctic y block - The "White Lythium" spray is also used to 'lube' fork lift channels/bearings.
Old Nov 26, 2006 | 11:09 AM
arctic y block
Never thought of using it for that. We use Tacky Lube witch is an open heavy gear lube. Nasty stuff. I will compare the price as I am sure the Lithium is more spendy. But should work better as an open gear and chain lube in these freezing temps. At least it will wash out of gloves. Hows it work on 5th wheels? You don't use it on say front wheel bearings on your trucks do you?
Old Nov 28, 2006 | 05:39 PM
George Frasier
arctic y block - The grease we use comes in a tube (for air grease guns) and is red. We buy it by the case. It can't be that expen$ive. I'll look tomorrow and get a brand & specific info. We also use the red stuff as a pre-lube when rebuilding trannys, etc.
