Oil Bypass Filter
Old Nov 20, 2006 | 04:56 PM
rad1026's Avatar
rad1026
Oil Bypass Filter
Has anyone tried the Baldwin set up? http://www.adiesel.com/prodinfo.php?stocknumber=BK1327
I can't find much info on it, like mounting position, etc. I wonder if it can be mounted down on the frame like the oilguard set up.
Old Nov 20, 2006 | 11:52 PM
jtharvey's Avatar
jtharvey
I haven't used that one myself, but Baldwin is typically a good filter. The base looks pretty universal, so it comes down to the element. I don't see why you couldn't mount it down on the frame, except it it pretty long (almost 12") and you might have some ground clearance concerns. Baldwin does make a 10" version of the same filter though, here:
http://www.adiesel.com/prodinfo.php?stocknumber=B7575
Old Nov 21, 2006 | 12:23 AM
SpringerPop's Avatar
SpringerPop
Look in my gallery. Photos and the details of the mounting bracket. I used a different Baldwin base and B-164's.
Pop
Old Nov 21, 2006 | 09:27 AM
ponch37300's Avatar
ponch37300
just wondering why this unit is only 63 bucks and the oil gaurd setup is 230? Is the oil gaurd that much of a better filter system to pay an extra 180 dollars? I would like to get a oil bypass system and any advice would be helpful since they all look about the same and cost anywhere from 60-500 dollars. Thanks
Old Nov 21, 2006 | 10:57 AM
rad1026's Avatar
rad1026
Springer, excellent photo's. Thanks for the documentation. Sure makes it easy to follow along.
Old Nov 21, 2006 | 03:51 PM
SpringerPop
rad,
If you're thinking of duplicating what I did, mail me at the link below and I'll give you the hydraulic fittings numbers. The filter base is a Baldwin OB1305, and it was around $25 from FleetPride. The B164's are under $8 each, same place. I had the hoses locally fabbed at a local hydraulic shop for around $60. I think the steel channel was $5, and the grade 8 bolts weren't much more than that.
Fleetpride in ABQ is at:
1919 BELLAMAH AVE. 87104
866.739.9013
Pop
