4x4 clunking
Old Nov 20, 2006 | 06:43 AM
syannuzzi's Avatar
syannuzzi
4x4 clunking
I have a 1983 F-150 4x4. When it is in 4 wheel drive it works fine while going straight. When I turn left there is a wicked bad cluncking sounds like the front axle shaft is just flopping around. Checked whill stopped I can reach in a wiggle the shaft alittle but wiggls the same on both sides.
Any ideas?
Old Nov 20, 2006 | 06:51 AM
Sycostang67's Avatar
Sycostang67
Sounds like a bad u-joint. Have someone you trust slowly roll the truck in 4wd and watch to see if it moves then.
Old Nov 20, 2006 | 12:45 PM
syannuzzi's Avatar
syannuzzi
How hard is it to replace?
Old Nov 20, 2006 | 02:16 PM
scottie2hottie's Avatar
scottie2hottie
depends on your skill. It isn't that difficult IMO, but i have done it quite a few times. You have to tear the whole spindle down. The only special tool you should need is an axle nut socket- about $15. the wheel joints are no more expensive than normal u joints so ~$20
