Valves ticking???
Old Nov 19, 2006 | 11:43 PM
psig8's Avatar
psig8
Valves ticking???
73 f100 with a 302 2brl,
just rebuilt eng and had heads rebuilt, runs like crap no.2 cylinder sounds like valves ticking but after checking ,it's the sparking that is making the ticking in the cylinder because if i pull the plug wire off the ticking sound stops, is this a stuck valve??? it ran perfect for about 200 miles.
I took a temp reading of header at no.2 and was about 320 degrees and all others were over 999 degrees my meter only shows tripple digits.
Old Nov 19, 2006 | 11:51 PM
Mil1ion's Avatar
Mil1ion
Not really a 73-79 truck question .
More like a general automotive topic.
I would inspect the wire for a broken end .
Are you putting di-electric grease on the top of the plug and on the inner connection of the spark plug boot?
How about exhaust pop from the exhaust manifold from that cylinder ?
That usually sounds like lifter tick.
Old Nov 19, 2006 | 11:57 PM
psig8's Avatar
psig8
no die electric, i can hear the spark in the cylinder but it's like it's not igniting the fuel which is what i don't understand.
Old Nov 20, 2006 | 01:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
Replace the wire and plug. Make sure you use dielectric grease on ALL terminals. The ticking is the spark jumping to ground on the OUTSIDE of the cylinder.
Old Nov 20, 2006 | 01:14 AM
psig8's Avatar
psig8
i'll try that, but it sure sounds like it's coming from the inside. thnks
Old Nov 20, 2006 | 08:23 AM
baddad457's Avatar
baddad457
Pull the plug and check the spark gap. Bet it's closed.
Old Nov 20, 2006 | 08:54 AM
psig8's Avatar
psig8
already pulled the plug and is good .035, but i haven't replaced it with another one yet as MIL!ION sugested, don't think that will work either but will try anything to keep from pulling the head again. already had to pull the head on the drivers side last week because the no. 8 exhaust valve was stuck. got that fixed and everything ran perfect for 200 miles.
Old Nov 20, 2006 | 09:19 AM
psig8's Avatar
psig8
just replaced the plug and wire, still runs ruff and ticking sound still there.
Old Nov 20, 2006 | 02:42 PM
baddad457's Avatar
baddad457
Pull the valve cover and roll the engine over with the starter with the coil wire off. Watch the rocker motion on that cylinder to see if it's opening the valve the same as the rest. Also check that the rocker isn't loose. Lots of wiped cam lobes here lately, yours could be one.
Old Nov 21, 2006 | 10:16 PM
Melchiah's Avatar
Melchiah
get a vaccum gauge on it
Old Nov 22, 2006 | 04:27 AM
HemiEater's Avatar
HemiEater
Yup the exhuast lobe could be junk.....
