will cam change timing
Old Nov 20, 2006 | 10:14 AM
ibleedblue1385's Avatar
ibleedblue1385
went from a stock 5.0 HO cam to a B303. should this change my timing, because the dist. is no longer lined up with the marks that it used to be to run.????? thanks.
Old Nov 20, 2006 | 12:50 PM
Kemicalburns's Avatar
Kemicalburns
was the engine at top dead center when you installed the cam? whats the cam in? maybe the distributor is 180* out.
Old Nov 20, 2006 | 03:48 PM
73FOMO's Avatar
73FOMO
Timing will not change by changing cam. If you turned the crankshaft you will have to bring back to T.D.C. You could possibly have the distributor installed one tooth off, or if it is 180 degrees off just pick it up and rotate back to your mark. You can usually just rotate the cap if a tooth off to make sure it is firing #1 cylinder at T.D.C. Just set the final timing with light after you start.
Old Nov 22, 2006 | 09:26 AM
darrin1999's Avatar
darrin1999
or if youre not careful on what cam you buy it could have a different firing order. 351 firing order rather than a 302 order
Old Nov 22, 2006 | 12:13 PM
EPNCSU2006's Avatar
EPNCSU2006
Cylinder 1 position remains the same between the two firing orders.
It sounds like the distributor wasn't reinstalled in the same position.
