MSD dizzy
Old Nov 19, 2006 | 10:04 PM
factory594x4's Avatar
factory594x4
Question MSD dizzy
Can I just drop in an msd dizzy? Will it match the stock harness? Do I need a spark box?
Old Nov 19, 2006 | 10:17 PM
arctic y block's Avatar
arctic y block
All self contained. at least the one on my marine Windsor is. Don't have the module number handy but it is at least 6 years old. Keeps popping the control module every few months. MSD said that was common on that model and would me glade to sell me a better/more expensive one. Or just keep a spare module around at about a 100 bucks a pop. Think I will see what Nappa wants for a point type dizzy If they have them for the Windsor.
Old Nov 20, 2006 | 12:06 AM
hatemakings/n's Avatar
hatemakings/n
there are two types from MSD for each engine family. One type is ready to run meaning it connects to the factory wiring through connectors or splicing. The other is for use with an MSD box like the 6a, 6al or 7 series. Make sure to ask when you call. I believe the ready to run model is more then the one for the MSD boxes. I ran the pro-billet with mechanical advance only and a MSD 6AL box with blaster 2 coil. I never had any problems once I put the correct springs in it.
Old Nov 20, 2006 | 12:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
You need vacuum advance on a street motor. Mechanical advance only distributors should only be used for full throttle racing applications.
Old Nov 20, 2006 | 12:18 AM
hatemakings/n
I would love to pass that info to the new owner but since the salvage yard bought my truck I don't think they would care. Maybe the lack of vacuum advane was the reason I was having trouble with timing at first.
Old Nov 20, 2006 | 01:00 AM
Torque1st's Avatar
Torque1st
Posting Legend
Probably, getting a vehicle drivable on the street without vacuum advance is difficult and it will not be efficient. A real gas hog. Most engines spend the majority of their time at part throttle where you need additional advance to burn the rare low pressure mix created at high vacuum. With only mechanical advance if you tune for part throttle it will ping like crazy if you get on it. If you tune for full throttle it drives like a pig at part throttle.
Old Nov 20, 2006 | 10:30 AM
hatemakings/n
And here I thought the poor gas milage was due to the Edelbrock RPM heads and intake and holley 750 carb. Guess I learned from my mistake again.
Old Nov 28, 2006 | 04:36 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Distributor
If you decide to get a new distributor, consider our D.U.I.-Davis Unified Ignition or our custom curved Duraspark distributor. Please see them at:
http://www.performancedistributors.com/forddui.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 28, 2006 | 05:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
Those didn't help any either. Sounds like you built a race engine and put it into a truck.
Old Nov 29, 2006 | 12:00 AM
arctic y block
Wink
Or a Marine engine that is at idle for trolling or 3/4 throttle to get to the next fishing hole or out run a storm front.
Old Nov 29, 2006 | 12:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
Well we don't really cover marine apps here on this truck forum. But any engine that is not run WOT most of the time needs additional timing controls.
There are many factors that influence ignition timing. In the old trucks we address two of them: Advance required due to engine speed is regulated by the centrifugal or mechanical advance system. Advance needed for engine load is regulated by the vacuum advance mechanism. The old "dumb" non computerized systems can't regulate advance well for mixture but it is partially compensated for with the load and RPM systems but only roughly. The "dumb" systems can't compensate for engine and air temperature at all. There are other factors like gearing and of course octane. We just have to hope we are not too far off.
Old Nov 29, 2006 | 12:51 AM
arctic y block
Red face
Well it dose have truck tin ware on a new marine long block. 351W But ya well put Sorry.
Old Nov 29, 2006 | 02:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hehe!
Have fun with it.
WyoExplorer
24
Mar 17, 2010 09:42 PM
firewoodtruck
Electrical Systems/Wiring
Jun 10, 2007 12:10 PM
Ratsmoker
Jun 13, 2004 07:43 AM
