automatic hubs
Old Nov 19, 2006 | 08:09 PM
joeboy4's Avatar
joeboy4
automatic hubs
Has anyone replaced the automatic hubs with manual ones? I have a 1993 f 150 with push button 4 wheel drive. One of my hubs are bad it will not disengage. I was told I could just swap them out with manual ones. Has anyone ever done this?
Old Nov 19, 2006 | 08:12 PM
ac700wildcat's Avatar
ac700wildcat
Yes you can put in manual lockouts. I'd buy a good set of aftermarket ones. Probably Warn.
Old Nov 19, 2006 | 08:14 PM
khadma's Avatar
khadma
Carpenter Local 745
I am sure most people here have gotten rid of those auto hubs, I have and I encourage most people to replace them.
Old Nov 19, 2006 | 08:25 PM
joeboy4's Avatar
joeboy4
Do I need to replace anything in the transfer case? The guy at the parts store seems to think I do.
Old Nov 19, 2006 | 08:34 PM
khadma's Avatar
khadma
Carpenter Local 745
No, pick up the new hubs and follow the instructions, job should take an hour at the max. Unless you want to do extra cleaning and maintenence.
There are six hex screws on the hub. Just remove them to take off the old hubs.
You will need a pick set to remove the retaining ring inside the flange. You can get the pick set at any auto store (o-ring remover), the set will have many different picks and you will use a combination of a few to get the ring out.
If ring does not lock back in, you must push the affected axle in towards the differntial housing (this situation may or may not occur) if it does post it and we can walk you through it.
Old Nov 19, 2006 | 08:45 PM
joeboy4's Avatar
joeboy4
Thanks for your help
Old Nov 20, 2006 | 06:52 AM
alz's Avatar
alz
You will also need a conversion kit. It is a new set of spindle locknuts. Add to that the correct spindle nut sockets. You may be able to rent these from local auto parts.
Good luck. Let us know if you need anything else.
Al
Old Nov 28, 2006 | 10:10 PM
ehollos's Avatar
ehollos
this in wrong area maybe but need to know if axle nuts are immediately behind hub on f3501996 4x4 front axle need to replace rotor ,auto hob but looks like not all of hub came out thanks
Old Nov 29, 2006 | 04:50 PM
joeboy4's Avatar
joeboy4
I got them in work great no conversion kit needed.
FordMan57
Jan 4, 2020 10:51 PM
powerstroker100
Oct 30, 2011 06:23 PM
regidog
Feb 28, 2010 11:51 PM
fordf350crazy
Mar 26, 2009 03:41 PM
d hendrick
Offroad & 4x4
Aug 2, 2003 11:28 AM
