Adding limited slip?
Old Nov 19, 2006 | 06:49 PM
Munky's Avatar
Munky
I have a 2000 F-150 with 8.8" gears and a 3.55 ratio, non-limited slip. I was wondering what all would be involved in making it limited slip? What all would need to be replaced and how much am I looking at for parts? Also is it worth making it limited slip and keeping it 3.55 or would it be more benefitial to make it limited slip and get a higher ratio (such as a 4.10)? The 3.55 does fine for what I use my truck for (daily driver, very very rare hauling).
Any and all input would be greatly appreciated. Even if you want to call me an idiot, feel free.
Old Nov 20, 2006 | 02:24 PM
pronstar's Avatar
pronstar
I went from 3.31 to 4.10 in my Expy. Street-sized tires (285-60R18).
Huge difference...for the better. Second best mod I ever did, right after the supercharger.
If you want to put new gears in, I'd do 4.10s or keep what you have. The change to 3.73 isn't significant enough (that's the only ratio that's in-between what you have & 4.10).
You can add LSD to your factory rear-end.
If you are thinking about re-gearing, I'd do everything at once so you save a little bit on labor.
I know lots of guys who put 4.10s into their F150s, Expeditions & Lightnings w/street-sized tires. These trucks range from stock to highly modified, everyone I know loves the change and I personally don't know of anyone who's regretted it.
(Guys with large off-road tires get even shorter rear-end ratios, like 4.56 or 4.88 or even shorter)
Old Nov 20, 2006 | 04:25 PM
Munky's Avatar
Munky
What would I have to replace to make it limited slip? Thanks for your feedback too on the 4.10's, that's what I'm leaning towards.
Old Nov 20, 2006 | 07:49 PM
pronstar's Avatar
pronstar
You just install it.
You have it or you don't, so it's just a matter of installing the LSD unit into your differential.
You'll have to replace your diff fluid because it will all fall out when you take the cover off, but as far as parts goes it just gets installed.
Old Nov 21, 2006 | 06:41 AM
Munky's Avatar
Munky
Awesome thanks again! I'll search around town to find it and see if it's something I'm comfortable doing my own or if I'll have a local shop do it. How much does the part usually cost?
Old Nov 21, 2006 | 10:19 AM
Clubwagon's Avatar
Clubwagon
Cost depends on the unit you choose. From about $350 for a cheap locker to $1500 for a quaiffe. Most LSDs are simple clutch type units made by Eaton or Richmond. These work fine for most apps and can be bought for $600 to $1000.
Its easy to install an LSD, you only have to pull the cover, remove the axle retainers and pull the axles out a few inches to clear the carrier. Then remove the carrier retainers and pull the diff carrier out. Then swap the ring gear to the LSD carrier (or install the locker in the OE carrier) and put everything back in. Be sure to properly torque the carrier retaining bolts.
Before you go swapping gears around check to see what the rpm change will be at cruise and then drive the truck in 3rd gear at that rpm and see if you are going to be happy with that.
From a 3.55 to a 4.10 *is* indeed a big change. Most likely 3.73 is the shortest gear ford put in that truck.
I went from a 3.31 to a 3.55 in my van and wouldn't want anything any shorter.
Steve
'95 Clubwagon XLT
