Another Refuling ?
Old Nov 19, 2006 | 12:09 PM
yamaguy's Avatar
yamaguy
Another Refuling ?
I have a 90 gallon transfer tank in the bed of my 87' and when I go to fill up I go to big truck lanes for the flow. Now I can't fit the big truck nozzles in my stock fillernecks(like I could in the Mostly Old Part And Rivets that I had) so I have to go to the auto lanes when I'm done and that makes me . Is there a way to make the flange on the fillernecks larger? thanks guys
Old Nov 19, 2006 | 01:57 PM
dwaymar's Avatar
dwaymar
Smile
can you say hammer and screwdriver or good chisel im from the older redneck world sorry but thats how i think don't fit get a bigger hammer
Old Nov 19, 2006 | 05:53 PM
yamaguy's Avatar
yamaguy
Yea that's how I am as well, I just thought I would run it by everyone first!
Old Nov 19, 2006 | 05:59 PM
fellro86's Avatar
fellro86
I can hook the tip into my fill necks, it just doesn't go deep... it is just enough to open the little cover, and straight in.
Old Nov 19, 2006 | 06:05 PM
yamaguy's Avatar
yamaguy
Yea but that makes a tigh seal and I think it might affect the tank venting? Plus when I do that I can't get it on the first click of the stop on the pump, so I can only put like 3 cents a second. What "little cover" are you refering to? Diesels don't have the covers on the fillerneck only gas burners if I'm not mistaken unless the early ones did.
Old Nov 19, 2006 | 06:13 PM
fellro86's Avatar
fellro86
Maybe it doesn't... worked on too many different vehicles lately... but no, you can't open it all the way up, even if you hog out the fill neck. I can get it to the first latch on a good day... be sure your tank vent on the top of the tank is clear, found mine plugged solid, now it works good again.
Old Nov 19, 2006 | 06:21 PM
yamaguy's Avatar
yamaguy
Yea I know droping my tanks is probably the only to fix it. oh well I will fix my sending units then while I'm at it. I can't tell if I have 2 or 19 gallons and I like to know cause I'm always towing different trailers and can't always guess my mpg. What's that about two birds with one stone?
Old Nov 19, 2006 | 07:55 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Pull the filler necks off the truck.
A cutting torch works well for removing the plate.
Bigger hammer, let's get serious and use a torch.
You can fix anything with a torch and welder.
Old Nov 19, 2006 | 07:58 PM
fellro86's Avatar
fellro86
I actually replaced my front fill neck with one from a gasser, and it had the same size hole in it as the original diesel neck does. The reason I had to replace it was because my last tire adventure tore it out, and the rear one was smashed so bad I couldn't even use it any more, had to drive back on my trip 600 miles from home without being able to use my rear tank... that sucked.
