1978 - 1996 Big Bronco
help
Old Nov 19, 2006 | 05:26 AM
robm397's Avatar
robm397
help
hello new to this site hope someone can help.
i have a 95 bronco 351 replaced tps and still getting 122 code and engine idles around 1500 rpms
Old Nov 19, 2006 | 10:16 AM
bobstrat's Avatar
bobstrat
i have a 90 with the same problem
so me and my last four hairs (ive slowly pulled the rest out )
are begging you
let me know if you get a fix for it.
Old Nov 19, 2006 | 04:49 PM
masseysbronco's Avatar
masseysbronco
You have to disconnect the neg battery terminal and adjust the new TPS to .6 to .9 volts. Anytime you install a new sensor you need to disconnect the neg terminal first so that the ECU can establish a baseline for the new sensor.
Old Nov 21, 2006 | 07:41 PM
robm397's Avatar
robm397
i had the battery disconnected when i installed new tps.turns out i had a defective part thanks any way
Old Nov 21, 2006 | 09:07 PM
alxsnmr's Avatar
alxsnmr
Bobstrat, I have chased the high idle situation myself and have a plan of attack for you if you want. I would like to know what you have done so far. I know the feeling of chasing and not getting the right thing to fix it.
