Basic info for changing Diff. fluid - 95 F150
Old Nov 19, 2006 | 02:57 AM
Skandocious's Avatar
Skandocious
I have a 95 F150 4x4. I'm changing the fluids in my differentials tomorrow and I've got a couple of questions:
(1) What weight gear oil to use for front and rear differentials.
(2) How much fluid each will take.
(3) How does the rear diff. cover seal (gasket or RTV)?
Thanks guys.
-Chris
Old Nov 19, 2006 | 11:38 AM
mississauga's Avatar
mississauga
I have always used silicon sealant on the covers with no problems. The place where you are buying the fluids should have the infomation for quantity and type of oil or it should be located in the glove box manual.
Old Nov 19, 2006 | 01:54 PM
andym's Avatar
andym
You can use 80w90 gear oil, it'll work fine. If you have limited slip, don't forget the additive or it will chatter if your clutches aren't worn out.
You'll need a pump of some kind to suck the fluid out of the front, there's no drain plug. Each should take a little less than 4 qts. For the rear, you can either use the cork gasket, RTV, or both.
Old Nov 19, 2006 | 03:11 PM
Skandocious
Fantastic thanks for the info. If anyone else has any words of wisdom please speak up! This will be my first time changing out the fluids on this truck. Thanks a bunch.
-Chris
Old Nov 21, 2006 | 08:31 PM
russelleotero's Avatar
russelleotero
just remember, its synthetic redline gl5 80-90w, i work at jiffy lube, do those all the time, and do not forget the limited slip additive
Old Nov 21, 2006 | 08:42 PM
andym's Avatar
andym
Synthetic gear oil isn't necessary, and is quite a bit more. If it were me, I wouldn't spend the money on it.
blue66tang95f150
Nov 2, 2014 09:44 AM
minnesotafisherman
Feb 23, 2011 05:46 AM
geoaigel
1978 - 1996 Big Bronco
17
Mar 23, 2006 09:21 PM
KYFord
Dec 3, 2004 11:50 AM
Pastmaster
May 17, 2002 09:42 PM
