Sponsored by: Real Truck
Adding 2" rear blocks on 2005 F250
Old Nov 18, 2006 | 07:32 PM
jwd1475's Avatar
jwd1475
Today I installed A front 2.5 leveling kit and added 2" rear blocks to the rear of my 2005 f250. Everything went smooth and the truck sits just how I wanted it to. My concern is the rear blocks are tapered and so are the factory blocks and together it makes the rear diff. point up on quite an angle and the drive shaft goes straight into the diff. Should I be concerned about this or is this normal? Would this cause a lubrication problem at the pinion bearing?
Old Nov 18, 2006 | 08:08 PM
tiredlr's Avatar
tiredlr
I Believe You Could Eliminate The Block Stacking And Order A Rear Block For An F350.i,m Sure Your Pinion Angle Would Be Right On.
beemr
Jan 31, 2014 05:36 PM
Johnny L
13
Apr 23, 2013 06:07 PM
ad326
Mar 25, 2010 05:12 AM
none2
Aug 23, 2008 08:31 PM
jwd1475
Oct 3, 2006 10:01 PM
