5th gear slipping out ?
Old Nov 18, 2006 | 06:47 PM
chopperz's Avatar
chopperz
Exclamation 5th gear slipping out ?
I have had this problem for a while 1,2,3,4 all work fine when I shift to 5th it stays until i accelerate then slips out? I pulled the transfer case the extension housin to reveal gears and items i'm not to familiar with I didcheck the syncro ring for damage and a visual didn't see any broken teeth or any sign of damage .....I heard sometimes it could be as easy as a loose bolt but again not sure about this area I need this problem fixed ASAP! any help would be great
Old Nov 18, 2006 | 08:43 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
My experience has been that when this happens it's a worn syncro and/or components immediately common to the syncro for the affected gear.
Old Nov 19, 2006 | 05:20 PM
racsan's Avatar
racsan
at least its 5th, i lost 2nd altoghter a couple of years ago, cost 1,100 for a rebuilt trans and i had to change it out in early feb in ohio in a drafty unheated barn. i wish it would have been 5th, id have drivin it till it was dead as only a 4 spd. as a test this summer i drove my weekly commute and didnt use 5th to see what effect it would have on fuel economy. it made only 1 mpg difference. over the 120 miles for the week it got 17, the week before (same route, empty box, same weather/temperature conditions) i got 18. it turns around 2,000rpm @ 55 in 5th with 3.73 gears and stock 235-15 tires. in 4rth it was 2,500 rpms.
Tom_Cat
Nov 21, 2016 07:44 PM
Hq254xp
Jun 3, 2016 06:42 PM
allimport
Feb 16, 2012 09:14 PM
Bluesmokestack
Dec 10, 2011 09:28 PM
bshep
Feb 19, 2009 09:26 PM
