1957 suspension
Old Jun 17, 2002 | 03:44 PM
truckfarmer's Avatar
truckfarmer
Post 1957 suspension
Old Jun 19, 2002 | 09:27 AM
ss427's Avatar
ss427
1957 suspension
I am getting ready to rebuild a 57 1/2 ton short bed and am trying to find out what front clip will fit the best. Volare, camero etc. The previous owner installed a 390 with a c6 and it only has 5000 miles so I am going to use this in the installation. Also any information as to a rear suspension would be very much appreciated.
Thanks in advance for all the information
Old Jun 21, 2002 | 12:28 AM
mercaddict's Avatar
mercaddict
1957 suspension
I also just purchased a 57 f-100 shortbed styleside and am contemplating what suspension to use. I have read many articles and talked to a few truck owners. Check out bonusbuilt.com for some interesting comments It seems ford frames were made of C-channel spring steel and they were designed to FLEX! Also note the crossmembers were riveted in, not welded in. I believe any attempt to stiffen this frame by boxing and welding is counterproductive. Any area that is not boxed will still flex. If you want IFS and I surely do, I think the best solution is an all new frame designed from the start to be rigid and let the IFS components do the flexing. I realize this may be contrary to what you are reading, but do a little research is my advice. Steve
Old Jun 23, 2002 | 04:51 PM
mercuryblues's Avatar
mercuryblues
1957 suspension
use a Mustang II kit for 56 ford little trim and it fits fine
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
